Pro 5.0 adjustable stop bolts??
Old Feb 19, 2004 | 06:08 PM
ADAMLS1's Avatar
The installation of my 5.0 will be this weekend and I've been reading about the stop bolts. Some install pages say you dont need them and some say you do? Any negative sides to backing them all the way off and tightening the bolts or just removing them completely?
Old Feb 19, 2004 | 07:00 PM
SHIZNIT's Avatar
I dont think you have to have them. The T-56 has built in stops from what I've heard. I like the stops and the "click" it makes.
Old Feb 19, 2004 | 07:29 PM
rwb's Avatar
rwb
I removed them completely from mine 2 years ago when I first put it in.
Old Feb 20, 2004 | 12:09 AM
Klypto's Avatar
i just adjusted them... might as well.. the few extra minutes it takes... why not?
Old Feb 20, 2004 | 01:04 AM
chpmnsws6's Avatar
use em, never trust the stocker
the forks can bend with the stock stops if you shift like i do..... fast and HARD
Old Feb 20, 2004 | 02:06 AM
AL SS590 M6's Avatar
Moderator
Yep, no stops is why there are so many bent shift forks. I'm using the stops on the Pro 5.0 in the SS. Why not?
Old Feb 20, 2004 | 09:44 PM
kinyu's Avatar
I use the stops in my car because when I race, I shift effen HARD!!!
Old Feb 21, 2004 | 12:02 AM
Valkyn71's Avatar
LT1 guy here, got a question for you pro 5.0 guys
I installed one on my 95 T/A and after a few weeks noticed from time to time, when i was really ripping thru the gears, on the 2nd to 3rd shift i would hit the divider between 1st and 3rd instead of sliding into 3rd.
anyone else had this problem or know what wrong with it?
Btw dont mean to hijack the thread, i used my stops
Old Feb 21, 2004 | 12:39 AM
ADAMLS1's Avatar
no worries. my thread is your thread.
I finished the 5.0 install and used the stops. I dont need a bent fork. I'll have pics of the install and the finished product up on my cardomain page sometime tomorrow.
Old Feb 21, 2004 | 03:06 AM
Moderator
Quit trying to aim for third. By trying to push it over into third you're hitting the gate between 3rd and 5th. The Pro 5.0 is designed to almost shift itself into 3rd. Put your hand right square behind the **** elbow horizontal and at your side and shove it straight forward it goes right into 3rd. You have to cup it and pull it towards you to hit 1st.
Go out and practice it while driving normally. Run it up to 3000 in second then just clutch and slam it forward. If it mistakenly hit 1st no harm no foul. You'll get a feel for it.
Old Feb 21, 2004 | 11:33 AM
Valkyn71's Avatar
Ill give that a try, thanks ALSS509 M6.
I hope that is my problem!
Austin
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Speeds8erM-1
Aug 15, 2002 10:07 PM
Speeds8erM-1
Aug 13, 2002 10:24 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
