View Full Version : LS1 Based Engine Tech
- Car wont start after Intake Install. HELP!!
- Lt1 Vs. Ls1 in 94' Camaro
- new rockes for a 408ci
- LT Header Question?????
- I've got some problems...
- Question on LS6 clutch
- Car warms up, then low idle and oil pressure after driving???
- Header Installation
- No oil at startup/#5 cylinder misfire
- Rear End Whine (yes i searched, have a ?)
- Launch
- Bassani Exhaust
- Need Advice!!
- Diablosport Predator
- Buying C5 on Sunday, Need some input
- Bigger injectors
- Loudmouth Vs Loudmouth 2 Which is better?
- Looking for Header Recommendations for 98 SS
- Borla?
- Lids
- Help! Engine Trouble
- Which coolant for LS1?
- Changed O2 sensor still not running right
- Hooker Headers
- Tranny swap question
- LS1, LS2 and LS6 differences????
- DMH e-cutout electrical?
- Who has went carbureted with their LS1??
- Turning a flywheel when replacing the clutch?
- What would be a good exhaust system???
- Edelbrock LT headers with sportline springs??
- Okay Ls1 Guru's Come Inside
- Funny noise from LS1
- Need to upgrade Clutch
- Octane
- Coil packs and Missfire
- What weight oil does everyone run???
- Car will NOT start. Need help!!!
- NEED HELP!!! WEIRD LS1 Sound....
- LID or K&N Setup
- Quick!! I Need Tq Specs!!
- cam and head question
- Need help ASAP, please!!!
- 519 RWHP from a bolt-on + H/C package??
- LS1 carb'd guys, get in here!
- Magnaflow catback review
- Trouble code after ls6 intake install
- Airlid questions
- SSRA vs. SLP
- oil catch can to keep oil out of engine
- synthetic to regular oil
- Engine mounts
- Muffler Question
- New Z28 guy
- how to tell what block it has...
- Buying Magnaflow, Which One??
- How to check out an LS1?
- rpo codes
- Anyone have pics of a Meziere install?
- Exhaust Opinions
- Fuel Pump/Injector ?
- Temp Gage
- Problems assembling my LT1
- Borla delivery 5 weeks?
- LS1 Specs?? Pls help
- tach out put question
- LT1 to LS1
- Need pics of PS cooler installed
- exhaust ?????
- Whats the best car cover to use that won't scratch the paint?
- thanks Cartek, Belts, overheating, SES light, whats next
- Is taking off the front fender easy on a 02 LS1 camaro
- Help - buying an 98 SS
- cam question
- quick 02 sim help
- LS1 & Backpressure
- Fuel pump question
- Air induction/exhaust, BEST SETUP FOR SS
- Do i need another tune??
- How Are These Flow Numbers For My Heads
- Precision Race Components Head Pics & Detailed Specs
- Magical screw?
- Replacing an in-tank fuel pump
- Getting the tr 224 cam, Whats diff between .112 and .114 lsa?
- how much hp gain might i get?
- Best Heads and Cam?
- What Is Wrong With My Track Times?
- Z28 governor
- Best fair priced OBD-II Hand Held scanner ???
- Need Advice!!
- Need a Cam Shopper
- Dyno - TR224
- Ticking Noise?
- Water Pump Alert
- Buying My 1st Camaro?
- Shorty Headers....Worth it?
- Crank Position Sensor
- dimming headlights
- Need Help With Mods:
- Just Dynoed... Sound about right?
- o2 sensors same part # front and back?
- slight knock/ticking sound
- 6.0L Buildup
- Parking Lights
- ss hood
- Best Cat-Back for LT headers???
- LS1, LT1 Steering Racks...Same?
- Cam swap packages
- 99 Z28
- Waste of money?
- Post your times
- Should I get a tune?
- Lets play diagnose my car problems :D
- removing grill
- How to clean MAF sensor wires?
- Z28 or SS
- How many miles/long have you had your FI on your LS1
- 2000 WS6 broke serpentine belt... what kind of damage??
- basic ls1 mods
- Went To The Track, First Time + Major Leak, Please Help
- Y-pipe??
- Disappointed
- Z28 car mat recommendation
- can you change heads with engine in car?
- Corsa
- Z28 vs SS
- SLP cold air
- Ram-air experience
- Fuel Pump
- programmer problems
- exhaust systems
- Turn Signal Don't Work
- What did I buy?
- What i need and how much Suggestions??
- Ls1 California Tunning
- SES Light on and off
- i smell antifreeze but there is no leak? (help)
- Jet Hot header bolts
- 2000 camaro z28 cats
- Swap..... Truck To Car Intake Manifold
- Corvette o2's...where to wire air/fuel gauge?
- Where is the fuel pressure regulator?
- Random Technology Dual Cat Highflow Y-pipe
- Horsepower
- Headlights
- Car hard to start, NOT holding fuel pressure...HELP!
- Which pulley should i get?
- stalling at low RPM
- Exhaust
- Cam only
- 1/4 times...need input/problems
- ls6 intake manifold coolant lines?
- LS1 pacesetter long tube felpro gasket part number?
- this is going to sound newb.. but smoke
- After one week of ownership, car dies on hi-way....
- 02 camaro prices
- tb, maf, by-pass, lid, bellows?
- What Should I Trap?
- ? Engine tick with oil change ?
- Changing plugs
- so how are those new headman headers #hed 68534
- What next?? MAF, Perted TB or Intake Manifold
- Wiring Issue
- SBC valves in a LS1
- How much potential do LS motors have?
- High Torque
- Need help installing Cruise control..
- Video of 11.2 Sec Truck & Burnout
- Subframe connectors and strut tower brace
- Need a FLYWHEEL
- Let's Play.. Guess My HorsePower!!
- SLP Loudmouth and Loudmouth II Cat-back question
- Excessive fuel consumption, help needed
- Code P0342
- LS or ZZ383
- GMMG exhaust
- Back from Korea and the car won't start--Please help!
- 98 A4...headers or stall
- New Camaro owner a few questions
- Black Zo6 Center Cap
- Nology?
- SLP Y-pipe
- Ls1 Pcm ?
- Flowmaster Catback question
- Which is a better (and easier) swap?
- Got B<R Tubular K Members cheap
- headers sounding like crap?
- Real Dyno #'s for SLP
- bolt on dyno numbers
- ohm testing injectors? obd code p0200
- Un catted?
- throttle body
- Hissing Sound?!?
- Washing your engine
- Hpe Cams
- 5th gear popping?
- Top Speed
- ummmmmm HOLY ****!!!!
- High RPM Knock
- Cleaning MAF Sensor
- LS1 idle problem
- Gotta Problem
- The Tornado & K&N, worth it?
- Salvage cam question
- I Need Help With Lt Headers!!!
- Any Headers that dont screw with ground clearance?
- Tap Noise tired of it.
- Thermostat
- Can someone help or give me some advice
- Interesting '02 LS6 Cam Article vs. '01 Cam & ASA Cam
- 2002 SS Camaro
- SLP loudmouth II ?
- Header install ?'s / help
- I need one of you guys to link me to one of your infamously helpful "how to" sites
- Where can I take my car to have the computer tuned - Detroit Area?
- Water temps
- Mods
- how much does the LS1 like 4k - 5k RPM playtime?
- What to look for when buying a LS1 Fbody
- what kind of MPG do u get in your ls1?
- WTF!! Change Oil Light
- 1998 z28 with 410s
- SPM & HPTuners Dyno Results
- Service engine light off with torque converter???
- Bank 2 # 2
- What are the compatibility problems with different LS1 Throttle Bodies?
- NEW PRODUCT - Hal Double Adjustable Shocks!
- LS1 Swap into 97 F-body
- Is a leaky power steering pump a common LS1 issue?
- chambered exhaust help
- O2 reading Oxygen below threshold in Cat
- Loudmouth I Or II?
- Ses
- LS6 heads?
- 4L60E Question?
- dynomax LT
- LS1 A/C Compressor
- catalytic con.
- Powder coating ZO6's
- Stenod Performance Twin Turbo Formula WS6 Project Car
- LS1 swap any info???
- Help me pick a new exhaust
- FlowMAster Cat BAck or SLP Loudmouth?
- Repair manual for Z28 1999
- Help my buddy make a good decision.
- Is my timing off
- Car wont start.. wont turn over at all.
- pinging tinkling noise only when in gear forw and rev
- 2000 SS Camaro 'cackles' when shifting gears?
