this is going to sound newb.. but smoke
I watched some LT1/LS1 exhaust vids, and on everyone white smoke comes out the tailpipe.. I thought that this was normaly a bad thing, and could be a symptom of a blown head gasket or if the car was just seafoamed. I started up my step dads 97Z and his 99Z, both in which have a Flowmaster exhaust system, and are stock all the rest of the way.. They both blew out white smoke at start up and a little diring rev's .. My car, 98 V6 even blows out a little smoke @ startup (i have a straight pipe +flowmaster) I know mine is because i have no cat..
Why?
Why?
Re: this is going to sound newb.. but smoke
If the smoke goes away, I wouldn't worry too much about it, especially right after start up. I know if it comes after a couple minutes and remains it could be the sign of partially blown head gaskets. White smoke at start up typically isn't serious - blue-white/gray is diffrent however...
I beleve the white smoke at start-up comes from the valve seals in the heads, its really no big deal alot of cars smoke a little on startup useally happens on older or modded engines.
Temperature will have an effect on it too - in colder weather the exhaust is much more visible - possibly from more junk condensing in the air, not sure
You're going to have some white puffs on start up of a cold engine. Most people get clips and vids of cold start ups because this is when any exhaust sounds its meanest.
well I know neither one of my step dads Z's have blown head gaskets because they both run perfectly.. The 97 with only a flowmaster catback run a 14.0 and we havent taken the 99 LS1 to the track yet.. my car ran a 15.8 tho Err... gay insurance companies, im getting an LT1 over the summer when i turn 18.
Jul 10, 2015 02:23 PM
