Swap..... Truck To Car Intake Manifold
I recently bought a 01 LS6 cam for my truck, should be a nice improvement over the 190/190 stocker. Well in the process i was thinking of swaping to a car style manifold. Has anyone done this and if so what exactly would i need.
I konw this much, the injectors wont work but what about the fuel rails? Also will the lower intake and T/B clear the accessory bracket?
If it is not too costly i might do the swap.
Any info would be awsome.
Faded
Faded
Re: Swap..... Truck To Car Intake Manifold
Get an LQ4/LQ9 manifold. They were tested to do a little better than the LS6 manifold by GMHTP. You can find one cheaper and I beleive your injectors will still work. F-bods just can't use them because they won't fit under the cowling.
You would need f-body fuel rails and injectors. Are you doing this for cosmetic reasons? If so, ok, but otherwise do like greed suggested and get the LQ4 or LQ9 manifold
ModdedNerd
Dec 14, 2014 10:28 AM
Jul 4, 2005 05:00 PM
