New Camaro owner a few questions
Old May 3, 2005 | 03:55 PM
Green98's Avatar
HI, im new to this site and camaros in general. I have always had mustangs so be patient with me. I just got a 98 z28 a4 a few months ago, Ive been hearing some wierd noises from it recently. before i brought it to a chevy dealer i thought id ask around first to see if any other z28 owners had the same problems. The main noise that is bothering me is a humming comming from the front left side of the car it starts after 35mph and continues the faster i go,it sounds like its something that is spining. also my oil gauge goes up when i floor it, is a real guage supposed to do that or is there a problem. Okay sorry for a few stupid questions.thank you
Old May 3, 2005 | 04:02 PM
sir dyno's Avatar
Re: New Camaro owner a few questions
The oil pressure going up when you floor it is normal.
The noise you hear from the left side of the car maybe a squeeking belt, easy to change. I got the same camaro as yours. For quick performance enhancement ad a performance lid. And no question is stupid.
Old May 3, 2005 | 04:03 PM
Green98's Avatar
Old May 3, 2005 | 04:10 PM
teke184's Avatar
yeah the easiest thing to check would be a belt. does it do it if you just rev it up? or only when driving?
could also be the tension pulley...they are well known to go bad.
Old May 3, 2005 | 11:06 PM
Green98's Avatar
It only does it when im driving 35 or above the noise spins faster too the faster i go , also is there any other problems that i should be looking out for with this model and year?
Old May 4, 2005 | 10:41 PM
robb4964's Avatar
Sounds like it might be a wheel bearing. A humming noise could be anything though. Its really something youd have to hear becasue its not good to make assumptions.
I have owned 3 4th gens and never had a huming come from the front of any of my cars nor have I heard it being a problem with any that my friends own so I wouldnt bet its a common problem.
Good luck finding it...welcome to the site!!
Old May 5, 2005 | 05:38 PM
Green98's Avatar
where and what is wheel bearing?
Old May 5, 2005 | 05:49 PM
sir dyno's Avatar
I would try the belt first. Just make sure to get a gm belt or else the aftermarket belt will still squeek. Its happened to me. Good luck.
cmdeshon
Dec 27, 2014 10:06 AM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
carcrazyQT
Sep 3, 2002 02:51 PM
