LS6 heads?
LS6 heads?
I recently picked up a set of heads, thinking they were LS1's. Just to be sure, I looked up the numbers but they did not match LS1 castings. A reliable source says they are "the mexican version of LS6 heads." What does that mean?
And if anyone could verify that this is what they are, the numbers are:
4229L3472497
0422911238322825
I don't know which number you may need. Also, on the outside of the head, where LS1 heads have a number 241, these have a 799. Any help is appreciated.
4229L3472497
0422911238322825
Re: LS6 heads?
I can't find the # you posted,but the ls6 heads have a "D" shaped exhaust ports and the ls1 has an oval-shaped exhaust ports.The Mexico,Silao plant built only the 5.3L truck engines Gen.lll V-8,I think that is right. Hope this helps you.
Re: LS6 heads?
the most common casting number is 243. as far as I know they are the same the springs are a little different but that is because GM upgraded the springs in 2003. as far as just the heads go they are the same, I have only had one set of the 799's pass through my hands, sent to me by a customer.
Hotrods&Muscle
Jan 28, 2015 09:35 PM
Hotrods&Muscle
Jan 24, 2015 09:57 PM
Hotrods&Muscle
Dec 21, 2014 03:57 PM
hotrodyou1
Dec 20, 2014 10:05 PM
