Dyno - TR224
Dyno - TR224
Just wanted to let everyone know that the tr224 is still putting up decent numbers. My 2k WS6 dynoed at 385/367. Mods are TR 224 112lsa, tsp lid, ls6 intake, kooks lt's, catted Y, magnaflow muffler welded into stock ws6 catback, spec III and some suspension stuff. I don't have a scanner, but graph takes off at 4k. AF was nearly a constant 13.1. Im hoping to get 400/??? if I ditch the cats and add a ported tb...
-M
-M
Re: Dyno - TR224
Yep - I plan on picking up a cutout, pulley and ported TB in the near future. If I can get over 400 w/only a 224 I'd be pretty happy. Right now my biggest concern is traction (or, lack thereof). 1st and 2nd gear are pretty useless if I lay into it pretty good. I think the next purchase will be some Nittos. I just hope my 10 bolt can handle 'em w/o exploding...
Re: Dyno - TR224
The lift on the TR224 is only .563 - which is pretty mild in comparison to most other aftermarket cams. The profile on the Tr cams is between that of the Comp XE and XER (so, more harsh than a comp XE grind but not so harsh as a XER grind). I am running 918s now and plan to swap them out for dual springs around 20k (just to be safe). However, spring life is really dependent on how hard you drive the car...
tdigger9899
Sep 7, 2015 10:56 AM
