Code P0342
Old May 4, 2005 | 11:56 AM
350 HRSS's Avatar
Code P0342
Yep, got this code this morning. It says it is for the camshaft position center-low output. Well, that is just frustrating. We changed out the intake and everything started up fine, no codes. But this morning, when it finally cranked, the code came up. I checked it w/ the Actron.
I found out where it is located-the back of the block, closer to the driver's side. I never unplugged this. Is it possible when we put the intake back on it could have been unplugged a little, or maybe it is broken? This code went away after I cleared it, and was fine. Even though the car ran a little sluggish. But when I cranked it again a little later, the code was back.
So, should I be searching for a new sensor (just in case), or wait and struggle to see if it is unplugged. I can't check it until after 4.
Anyone else go through this when they had their intake out? This is a 99.
Thanks!
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
