I Need Help With Lt Headers!!!
Re: I Need Help With Lt Headers!!!
Blinking SES light= BAD misfire. Change your plugs & wires, if it's still doing it then have it scanned.
Also, if you haven't installed your O2's yet... do it right away.
the sims will get rid of that code in the engine. but NOT having them won't cause a blinking SES.
i'd bet you have a bad wire, plug or a BAD exhaust leak.
but remember no rear o2 sensors has NO affect on the running condition of the car
Instead of getting o2 sims, just get a mail order tune to delete the rear o2's and while you're at it, get the car tuned for your LT's. If you deleted AIR and EGR get those codes taken out as well. Much simpler IMO then hassling with o2 sims when dealing with LT's as they only have provisions for the front o2's in the collectors.
If this doesn't take the code away, you need to replace the front o2's as these are what send the PCM air/fuel data to make the car run right. If/when you get new o2's for the front, get some rear o2's for a 2002 Vette. Also Bosch 13111 o2's are popular as well for us LT guys. The front o2's are placed farther from the engine and don't get as hot as they did with the manifolds so you're gonna need higher watt o2's to compensate. Otherwise you'll just run rich. Trust me this is a common problem when installing LT's.
Jason
Jason
colts0455
Jul 28, 2015 11:28 PM
