Which pulley should i get?
Old May 7, 2005 | 07:25 PM
z28man86's Avatar
I have a 98 Z28 and i want to get new pulleys. Which set of pulleys should i get the Auto Specialties or the March?
http://www.thunderracing.com/catalog...vid=3&pcid=111
And i assume i would need new belts.
Old May 8, 2005 | 07:37 PM
Bayer-Z28's Avatar
Re: Which pulley should i get?
March, it has a dampener on it...And yes, you will need new belts..They should give a P# for the one(s) you need...I'd look into the ALT pulley also..It will correct the RPM differences with the ALT so you will charge the same at idle..
Old May 8, 2005 | 08:20 PM
RS Dragster's Avatar
I've got the ASP and haven't had any problems. It's also what 90% of the other guys in the local group have. Good stuff
Old May 8, 2005 | 08:25 PM
80TA's Avatar
I had asp underdrive bolt on and overdrive alt on my 97 ta a few years ago.It worked ok but that car was m6 .I also thought it added some harshness .
This time I went for asp underdrive balancer slightly less underdrive than the bolt on ones. So think it should be fine in my auto but if not then also have the overdrive alt pulley .I got my set used. They are very very hard to find in stock usually. I waited a long time. Also its debatable whether the pulleys do much on the lt1 as not as much is driven off them. But will see how they work in a few days when get them installed.
Old May 8, 2005 | 10:13 PM
Antz97ZNJ's Avatar
Most LS1 guys go w/ the asp
AviatorDave
Dec 19, 2016 06:35 PM
RUENUF
Mar 13, 2016 03:37 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Slayer
Aug 17, 2015 03:55 PM
