Water Pump Alert
Guest
Posts: n/a
Water Pump Alert
I brought my '02 SS to the dealer under warranty to cure a slight miss at 1500 RPM or so. They determined I have no miss (I do!), and also found that the waterpump needed replacement (at 32,000 miles!). There have been several posts about owners noticing a whiff of coolant now and then. I would advise you to check the water pump for seepage. Incidentally, with the new pump, the engine is much quieter. I didn't realize the racket the old pump was making.
Now, about that miss. Can anybody recommend a tune-up shop in the San Diego area?
Guest
Posts: n/a
Re: Water Pump Alert
Originally Posted by MeanZ687
What kind of noise did your water pump cause that made it so noisey?
so all that work and they didn't fix the miss?
i mean...you said the told you there wasn't a miss...all that takes to determine is a scanner
sounds like you need to have a chat with the dealer
i would check your plugs and wires first, they are common causes of misses.
sounds like you need to have a chat with the dealeri would check your plugs and wires first, they are common causes of misses.
Guest
Posts: n/a
Guest
Posts: n/a
Hey Bayer-Z28--
I checked out your (car's) webpage. Very nice. Thanks for your service to our country . . . And keep your head down, man! That's quite a rig you operate in Saudi. Ever do a 1/4 mile time with it? I know, you'd need a calendar.
Blood type Z28
Apr 8, 2015 11:34 PM
