thanks Cartek, Belts, overheating, SES light, whats next
Old May 21, 2005 | 11:29 AM
Njgunslinger's Avatar
Damn, picked my car on on Tuesday from Cartek in Garwood, NJ after the put on heads, cam, gears, ASP pulley, Dyno tuned and it drove nice, Fast. Then the problems,. Thursday, got on it a little, both belts broke...ok, I replaced them, seemed ok.
Friday night, SES light comes on, well no biggie, maybe a sensor, will have that code checked.
Saturday day, car ran fine on the highway, then took it home, cleaned it up, went to the store, had it idling for 5 mins., started driving it and booooom, temp gauge starts shooooting up, 2 mins later, at 260!!! Parked it, let it cool off, checked the Radiator fluid, looked fine.
No leaks anywhere.
Checked the coolant measuring stick, light brown murky, but not oily..
Checked oil, looked fine also.
So what is causing t his to overheat...Thermostat sticking? Blown head gasket, waterpump???
Called Cartek, no one there..
Old May 21, 2005 | 02:17 PM
Re: thanks Cartek, Belts, overheating, SES light, whats next
Just ran the car for a while in idle and the temp finally went over the 210, climbing, and the fans never turned on.
Is that thermostat?
Old May 21, 2005 | 03:14 PM
OKKK replaced the fuse for the cooling fan since it was blown, and the new fuse blew...Anyone hear of any problems with this, especially after ASP pulley was replaced.....
Old May 22, 2005 | 02:24 AM
ULTIMTEORANGESS's Avatar
id just try to contact cartech as soon as you can and bring it back to them.
Old May 22, 2005 | 12:22 PM
mrr23's Avatar
either have a positive wire grounding out somewhere or fan motor crapping out causing too much load and popping the fuse.
warmeck
Apr 16, 2015 05:50 PM
Gtpguy
Jan 26, 2015 04:50 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
Z28Wilson
Aug 1, 2002 04:27 PM
