pinging tinkling noise only when in gear forw and rev
sound like it comes from were torkconverter is and i have a aluminum driveshaft .thought maybe cracked flywheel but it does not do it in park no mater how high i rev it .does it only under load.hmm
When my converter took a dump
, I had a pinging/ticking noise, but it did it at idle in park as well and was consistent w/ engine RPM's .
Converter pump going south, perhaps ?
Bearing issues ?
Hard to say .
Have you tried posting in the drivetrain section as well ?
http://web.camaross.com/forums/forumdisplay.php?f=44
Britt
, I had a pinging/ticking noise, but it did it at idle in park as well and was consistent w/ engine RPM's .Converter pump going south, perhaps ?
Bearing issues ?
Hard to say .
Britt
