WTF!! Change Oil Light
Originally Posted by kickinthehouse
so i just got my oil changed land 100 miles later the damn change oil light is comeing on when i start the car wtf ???
Just because they changed your oil doesnt mean they reset your oil sensor. Hold down your reset stick , you know the thing sticking out of the plastic right in front of you . You need to hold that in for at least 10 sec for it to reset the oil change light .
It also explains it in detail in your owners manual . Good luck
Rob
Re: WTF!! Change Oil Light
Could be the sensor is messed up. Turning the key on to the run position (point where power accesories are turned on) and tapping the gas 3 times is the way I do it. The odometer way doesn't work as well for me for some reason.
Read the manual
You dont tap the gas 3 times , you turn the key from start to run 3 times . Something like that . Rob
Originally Posted by siggs229
Read the manual
Rob
My way is a common way among many cars and isn't in the manual.
You love the manual so much why don't you marry it.
I think were misunderstanding each other . Im trying to help you . When you say " tap the gas " do you mean turn the motor over ??
Rob
No you don't turn the engine on. You turn on the power (key position BEFORE ignition) then tap the gas three times.
OK , last question . Could you explain how tapping the gas helps ? Maybe for good luck ?
You have to hold in the odometer lever in to reset the oil change light . Its a feature in the newer camaro models . It trys to tell you when to change the oil . Based on conditions then car goes through with the sensors in the car go then they go to the computer . And then you had an advanced idiot light
Next time your oil light comes on try it smart guy I'll be here for ur apology.
Keep that blinker fluid topped off.
Why wouldnt I just do it the right , simple way and be done with it ?
Like I said I have had better experiences doing it this way. My change oil light comes back on after a drive or two when I do it the other way. I mentioned this other way in case the oil change people did reset his change oil light but it came on already. Also, this is a common way so it might be easier in the long run.
How to Reset the Oil Change Light
After changing the engine oil, the system must be reset.
With the ignition key in RUN with the engine turned off,
push the TRIP/OIL RESET button located on the
instrument panel for 12 seconds. The OIL CHANGE light
will start to flash to confirm that the system is reset. The
reset is complete when the OIL CHANGE light goes out.
Source - http://shbox.com/pdf/manuals.html
Read the manual
Rob
Then you spin around three times and put your right foot in.......
Mine did that too a while back, I just changed the oil agian and reset it! Didnt come back on!
just fix is perminatly. Take the gague cluster out and take the light out that lights up the change oil light. And never have to worry about that dumb thing again. If you need some light to tell you when to change your oil you don't need to be driving a car in the frist place. Just my $.02
