catalytic con.
Old Apr 24, 2005 | 07:40 PM
calee's Avatar
catalytic con.
will a catalytic converter from a '99 fit a '00 camaro? Thanks for the help.
Old Apr 24, 2005 | 09:14 PM
Greed4Speed's Avatar
Re: catalytic con.
I would think so.
Old Apr 24, 2005 | 11:22 PM
calee's Avatar
Re: catalytic con.
Thanks,I am going to buy a used set and gut them, and when i need to get a state inspection, I can put the stock ones back on.The off road pipe are a lot of money,and i see cats for sale as low as $30.00.Do you think this is a good or ok way to help with the exhaust flow? I am trying to keep the car stock and at the same time get the most out of it.Everything i have done so far, i can put it back to stock in 2hr.Thanks for your input. Cale
Old Apr 24, 2005 | 11:52 PM
SocalZ28's Avatar
Re: catalytic con.
you know, 3 inch high flow cats from random technology will give you better performance, a very good sound, and their street legal and will allow you to pass smog. If you've never run a car with a gutted cat before, your in for a big surprise, you'll be high as a kite in five minutes from all the hydrocarbons building up in the cockpit, believe me i know, i run a gutted cat *currently saving up for full exhuast system* i only run it because the stock cat became clogged and the car couldnt run.
Seriously look into getting some high flow cats, their better in the long run.
colts0455
Sep 22, 2015 02:03 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
Slayer
Aug 17, 2015 03:55 PM
wbacall
Jun 22, 2015 10:04 PM
