Quick!! I Need Tq Specs!!
Old May 29, 2005 | 01:48 PM
Bayer-Z28's Avatar
I can't find my install manual, and this computer sux, can't open anything.
What's the TQ spec for the SLP LT's on a 2000 LS1???? Header to head bolts..
Old May 30, 2005 | 06:13 AM
BirchMan98z's Avatar
Re: Quick!! I Need Tq Specs!!
Around 15-20 ft/lbs will do it. Really there's no torque spec for the header bolts, just hand tighten them, and use a ratchet to make them as tight as you feel is safe.
Old Jun 1, 2005 | 11:10 AM
Bayer-Z28's Avatar
Well, I found them. I was pulled off the project for a while. I went up to my cousin's and looked it up. It was 11ft/lbs on the first phase and 18ft/lbs on the final. It took me 14 hours to do the install. The pass side was a major PITA!!!! I had to trim the K-member and loosten the trans mount, move everything around just to get this one primary to slip in!
Novo
Jun 14, 2016 02:58 AM
68camaroboltz
Oct 5, 2015 11:56 PM
cmsmith
Sep 14, 2015 09:09 PM
NewsBot
Sep 14, 2015 09:20 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
