- OBDII Idle Timing
- problem with PCM
- How to retard ignition timing using LT1 edit
- Laptop minimum requirements?
- Freescan question??
- Correcting A/F ratio with tuner Cat ?
- New to the reprogramming side of the house...quick question
- Benefits of increasing injector flow rate?
- DIY-WB almost done, but NEED HELP!
- Are there any LS1 tuner's in the North West Region?
- New to all this and have a ?
- New Laptops and Tunercat, serial port and USB
- 96 hypertech work on a 94?
- anyone have a true fix for the odb 1 high stall no shift problem?
- new pcm/ base program ?
- What about the chip?
- Third Gen Chip Reprogramming
- How much would you pay for OBDII tunning cable and software?
- would using a HPP with a cammed car work?
- rough running engine and lost power.
- anyone ever heard of using a paper clip?
- Anyone have or know where a 230/236 file is??
- TechEdge WB narrow band output ?????
- Tryin to stay cool, can anyone help?
- Setting Closed Throttle Spark Advance?
- tunercat users
- Black dot to the left.....
- MAF table adjustments...
- tuning a heads/cam car
- Forcing PCM to run diagnostics?
- Used Pcm
- dyno tune
- Running OBDII PCM and OBDI Knock Sensor...
- s.a.f.m
- Venom 400??
- How hard to use LT1 edit?
- Can LT1 Edit Cause Computer Problems with frequent use?
- Definition list??
- knock retard
- TTS datamaster fuel readouts.
- Maybe its not the Opti-Spark
- MISTERY Detonation
- Is tuning really needed with 1.6 RR?
- Unusual OBDII to OBDI question...
- F.A.S.T Part Numbers
- flat spot, 1000- 2000 rpm/tunercat
- Switch to OBDI, now fans won't turn off
- How to change a/f at wot in Tunercat??
- tunercat problem
- 42lb injectors vs ?
- I need a how to on OBDI conversion
- I need a stock 95 a4 2.73 .lt1 file please!!!
- Trying to load PCMfor less;cable error ect. need help
- Paging kevin97z28 or anyone else thats familiar with F.A.S.T
- hooking latop up?
- Available reprogramming from GM itself?
- Senors ignored in open loop?
- Atlanta area help
- obd2 free scanner?
- T56 to A4 swap PCM question
- code 72
- LT1 Edit!!!
- LT-4 With Hot Cam using LT1 edit. How much can you advance the timing?
- tunercat/lt1edit
- Can Freescan Work with a '95??
- i would like to say Bryan is the MAN!
- Exactly what does tps% used for?
- Whats the cheapest way to scan/tune OBD2
- Any Way To Remove The Factory Speedo Limiter Myself????
- Is There Anyone Who Will Program A 96 3.8 Computer?
- stupid question
- Are all ABS reluctor rings created equal? :)
- Question for TunerCat users... Please read and post...
- Help needed--rough running
- My TunerCat issue update.... Long, but you Tuner users need to read.
- Reseting 'check engine' light after an accident
- What are my options for a 96 OBD2 SS
- Help! MAF problems
- Minimum requirements on laptop for custom programming?
- sir dtc
- tuning for ls1 hot cam
- What the hell does this mean!?!
- Think I fried my PCM...doh!
- Emergency brake light
- laptop speed
- Lost my PCM again using TunerCat....
- Predator tuning guys, what did you set your spark advance to?
- Will this work?
- Scanning.. help, please
- TunerCat retry after getting dead PCM back...
- How to upload Programming
- DFI kits
- autotap tuning software opinions and info needed
- Edit Settings for 160 Thermo?
- dtc help
- OBD2 W No Crank Pos Sensor???
- Help please
- ABS Software?
- I'm going Stand Alone, any suggestions?
- lt1 edit ?
- What tuning program should I get?
- Open loop and Nitrous?
- Trade Tuner Cats for Datamaster
- VIN info
- High Knock Retard...
- Tuning for PE mode
- pcm tuning after porting heads?
- shock sensor for alarm
- invalid com port specified
- advancing spark and leaning out afr
- Starting tunercat
- Any tuners for a 96 3.8l?
- Someone please help tell me: is it the computer????
- What port does the laptop need to have?
- Accel DFI?
- TunerCat help needed please....
- Relating a misfire to the PCM!!
- A 98 v6 a4 camaro computer problem!
- Smog pump removal, will it setoff any codes?
- Is there any OBDII cable available to reprogram PCM?
- Anybody else doing OBDII tuning besides Carputing (LT1edit LS1edit)?
- Weird things with TunerCat
- old police laptops on Ebay
- FreeScan/Data logging software
- stockish lt1 tuning
- what does this code mean?
- Which is more user freindly... Tunercat or LT1 Edit?
- a few ?
- converter locking and unlocking on top end run.....
- closed throttle decel surging (I got data!)
- Dumb question
- Installingthe FAST today.Any websites?
- LT1 question?
- MAF and injector Q.
- Knock?
- Fuel Trim values....
- How hard to learn the Lt-1 edit
- ALDL Cable question
- Can timing be adjusted in between 100 KPA and max boost at a given RPM?
- BLM contents
- trouble code
- Need tune program for LT4 383 w/comp 305 cam
- Is it possible to lower my injector duty cycle?
- Need keyless programming instructions for a 2000
- Just got the Tazzo Vehicle Performance Computer
- How do you tune for 30# SVO f.i. with tunercat
- Hypertech ?'s
- Do I need Tunercat if...
- shift softening procedure ?
- Wiring up new 4L60E connector
- Scan Master
- Is there anyway to keep fuel psi's the same with pcm tuning?
- Inlet Air Temp questions...
- Fixing split BLM's due to AS&M 58mm TB.
- Do you agree that this has to be true knock?
- tunercat-How do you make it run?
- FAST Harness, where to start?
- Auto-Tap Tips???
- can someone edit my lt1 file for me?
- Question on PCM tuning....
- msd 6al
- scanmaster and datamaster
- what is avalible to scan '93s?
- DTC help!
- OBD ll PCM Tunning in Central Texas?
- Stuff needed for a 93
- Bigger Cam & Idle Misfire Problem
- stock computer
- APEXi Super AFC
- ? on a rebuild, with a paxton(computer issue)
- Bad pcm causing po200 code??
- computer chips
- soft wear for obd2
- VSS questions
- pcm tuning
- Anyone have M6/LT/Pulleys/CAI tune?
- How can I convert 4k/mile vss to 2k/mile?
- Pcm tuning
- obd1 conv, and adj fuel press reg.
- can I make my car open loop?
- 93 PCM help
- Same heads, same cam, now a 383??
- hypercrap and alternatives
- PE mode and n2o
- Stock ECM
- (fbod vs vette) ecu's
- big cam and emissions
- What do I need to get started tuning the car myself?
- lt1 edit
- Could I get away with...
- Whats needed to use Tunercat on '95 LT1?
- Dynotuning
- Greddy air/fuel gauge vs DIY wideband
- what exactly do they do to a pcm when reprograming?
- Mem cal adapter for OBD1 chip burning?
- 1.6 RR's now lean on throttle tip in
- Can LT1 Edit Program Out A Traction Control Code?
- Does anyone know how to bypass the driver side airbag
- OBD II diagnostics scanner......
- Using HYPERTECH
- Keyless remote ??? yup another one
- Has anyone eliminated the stock PCM
- datamaster software
- stock pcm tuning
- Need to see what engine sencors read
- Who needs a laptop?
- Car running rich. what do I change; lt1 edit
- Puter guys... please tell me how... (IRQ)
- Look at these files part: 2
- Whats Needed...93 to OBD1???
- TPS%vsVoltage
- OBD II connectors
- HPP3 question
- hot cam tuning question?
- Newbie to tuning:What software do I need for my 93 ta
- Quad Drivers?
- Pcm
- ScanMaster for a '93 Z28
- Questions for TunerCat owners
- anyone want to trade their OBD2 edit and PCM for my OBD1 edit and PCm?
- Did I ruin my PCM?
- Logging problems with Freescan and PCMComm. Also...
- what type of tune do i need??
- afr at idle?
- Palm 515 for you guys
- i'm scared :(
- FAST computer guys. In please
- Tunercat help
- Tunercat file needed
- what would be programmed on my puter if i sent it in
- Anyone using a open loop tune
- PCMFORLESS questions
- XE230/236 be tuned to pass emissions?
- Help! I can't get online anymore!!!
- Hmmm....should A/F ratio lean out as rpm increases
- Continued Laptop Problems..
- Tuner Cat for 94 LT1
- PO154 O2 sensor circuit no activity( bank 2 sensor 1)????
- LT1 edit & Datamaster, will they work on a Palm or win based hand held
- OBD2 troubles w/'98 Vortec 350 (van)
- Can somebody send me the software for LT1 Edit?
- Guys running a FAST and Boost. In pls.
- Hypertech Power Programming with LT4 Hot Cam Kit?
- is this possible....
- Rear window defoger
- HELP! PCM locked-up
- Needhelp please view and give me your thoughts..
- 1990 4x4 silverado tuning
- Need PE/dyno help ASAP!
- Please take a look at these files!
