PDA
View Full Version : Computer Diagnostics and Tuning
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
  1. Best Tunning Programs??????
  2. Do I need bigger injectors
  3. P0400 code
  4. Datamaster questions
  5. Need Computer Chip for 5.7L V8 94
  6. Cable failure..
  7. When to tune...
  8. Car goes nuts when it goes into closed loop, 02's? look at my data logs
  9. MAF Tune for E85?
  10. Shift Kit need tuning?
  11. looking for bin file(s)
  12. Where to start on open loop tune?
  13. Differences between 94 and 95 LT1 programs?
  14. Can only get 10PSI of boost
  15. Security light + vats programmed out
  16. diablo sport
  17. OBD1 vs. OBD2 tuning questions
  18. How to change rev limiter
  19. Disabling skip shift with LT1 Edit
  20. Boosting fuel pressure ?
  21. stroker tuning
  22. 1993 ecm covert to 1994 pcm
  23. Head cam, loading up on fuel at idle, Need help
  24. Is Madwolf still doing Tuning
  25. Help with freescan file
  26. Narrow bans simulation
  27. converting serial cable to usb
  28. Tuning for 96: JET, LT1 edit, obd1 conversion?
  29. IAC Park postion vs. Coolant temp(cats)
  30. 93 prom chip
  31. Fast dual wideband 02 controller ?'s
  32. need to double check stuff, injectors/tb
  33. Inside the mind of an OBD I?
  34. Quickie about diablo sport
  35. can someone diagnos these scans please?
  36. cant connect to read code
  37. Quick O2 sensor question.
  38. Reprogram computer to allow use of trans from a different year
  39. Running rich?
  40. how many people run with there knock sensor zero'ed out?
  41. solid mounts causing me to pull timing?
  42. 95 firebird vat bypass
  43. BCM Codes, Can anyone tell me where to start?
  44. Hypertech programmer III question?
  45. speedometer problem
  46. What should I change in C.A.T.S w/ these mods.
  47. Strange 02 data logs
  48. Tuning newb ?'s Added heads.
  49. wiring an a4-m6 swap
  50. VE Master?
  51. datalog 93 lt1
  52. Is there really much to gain by having a chip burned on a '93 SD car (bolt-on)?
  53. Cheap programming for 96-97 OBDII?
  54. Will tunercat & freescan work with usb?
  55. o2 ?
  56. inverse temp term vs mat
  57. Problem Logging Wideband Thru A/C Sensor
  58. Data Master Help
  59. Battery Drain over night
  60. wideband MAX lean when WOT...log seems good?
  61. Need Your le2.2 or le data master logs to see whar i shoud be at
  62. Need Your stock lt1 datalogs.
  63. What is your AFR when you are decelling?
  64. looking for a bin file for tunercat 94Z28
  65. difference in pcm's
  66. Someone take a look at my tune? Opinions?
  67. 95 PCM controlling a 93 LT1
  68. Open Loop, Speed density. Fuel Tables Used?
  69. Help with hooking up laptop to PCM
  70. PCM - MADZ28 (Madtuner) or PCMforless?
  71. WOT to Rich, How to lean. PE tables are 0
  72. OBD II Software Scanner
  73. Irratic wideband...MALF codes inside (datamaster)
  74. How much HP/Torque does a tune gain you
  75. limp mode?
  76. DIYEFI.org, FreeEMS and the future of TRUE DIY engine manage
  77. can't get wot timing below 26 degrees
  78. tunercat and freescan unable to establish communications with PCM :(
  79. Need to richen up at WOT - which tables?
  80. Quick question
  81. will an automatic LT1 ECU work in a 6 speed car?
  82. little confused with tunercat
  83. Anyone with DFI
  84. changing to straight distributor
  85. dash wiring ?
  86. stock injector flow rate
  87. wiring and tuning
  88. Tunercat def file... I reformatted
  89. Shopping for a Wide band
  90. Opti spark wheel / output ?'s
  91. Open Loop Speed density, A/F not changing
  92. Tuner C.A.T.S or LT1 Edit??? (95 LT1)
  93. How can I test my OBDII connector?
  94. mail order tune with high altitude
  95. I NEED A CAR FAX...please???
  96. Time for a tune
  97. MadZ28Tune??
  98. Link Error Pcm Scan
  99. Help with harness conversion please
  100. Where to get your version of DataMaster
  101. No start after pcm read attempt
  102. 95 stock bin file
  103. LE2 383 1stStart Up - Scan/Log Attached
  104. killed my pcm with efilive
  105. Please look at my scan and let me know what you think.
  106. scan guage question
  107. Tuning Programs - LT1/LS1
  108. No power to diagnostic port?
  109. More timing that what is commanded?
  110. Rec. a wideband set-up
  111. Gauges out: Oil pressure, engine temp, fuel
  112. Best PC scanning tool
  113. Jet Dynamic Spectrum Tuner 14005
  114. How do you tell if rich or lean during WOT?
  115. cable questions
  116. 1994 to 1995 pcm
  117. I need a Stock 96 M6 tune
  118. Understanding DataMaster EE 3.4.1
  119. Ignition module required?
  120. Obdii Dtc P1416
  121. Pass-Key & Key Bypass (shoebox's Diagrams)
  122. Added Lt Headers, How Do I Tune? Lt-1 Edit
  123. Help with TunerPro RT
  124. opti wiring harness...
  125. how to get datamaster to work?
  126. tuning near stock 03 vette
  127. Making an O2 simulator
  128. About shoebox's PCM Connector diagram
  129. God place for LT1 dyno tuning in the northeast?
  130. Hypertech PP3 Reprogramming?
  131. leaning out idle cc305
  132. 97 z28 LT1 swap into a 92 RS 3.1 HELP!!!
  133. flashing lights
  134. Will Freescan work on VISTAs?
  135. Diablosport Predator Programmer Question
  136. b4 you try tunercats,please read
  137. pcm read issue w/ tunercat
  138. Newbie cam tuning questions
  139. Different split BLM question
  140. PE Fuel Curve, Speed Density vs MAF
  141. Questions what to do after tune
  142. So what are the Pros and Cons of some of the aftermarket computers?
  143. Finding datalogs with similar mods as mine
  144. hypertech programmer
  145. Need to flash my PCM ....
  146. Tuner Cat WOT on LS1
  147. tunercat vs. tunerpro
  148. can anybody please translate the meaning of this obdII code
  149. Wideband o2 question
  150. x24 Reluctor Question
  151. Do i need to wait before logging the car?
  152. Pinging on 383 with stock timing
  153. Odd issue in Cell 6
  154. Security light?....
  155. Car runs with fuel pump relay?
  156. LT1 tuning write up
  157. Progam Remote
  158. probably a stupid question....
  159. Why would deleting O2 codes cause PO1133 an PO1153
  160. False Rich Condition
  161. considering buying Autotap
  162. Security light always on 97 LT1..Anyway to reset
  163. Datamaster v3.4.1 anyone
  164. tps sensor
  165. TTS Datamaster. How does it work?
  166. wiring using stock PCM and XFI
  167. Wideband says fine, pcm pulls fuel
  168. tuning programs
  169. Low Z injectors Lean Tip In advice needed
  170. PE idle 95 car.
  171. need help computer tune
  172. Noob Questions about Software and a cable for 94obd1
  173. What FTP site best to use to export csv datalog???
  174. 1995 Z28 code 43 runs sluggish, Help Please?
  175. Need stock 95 LT1 A4 .bin
  176. trial tunercat Q.
  177. another wiring ?
  178. What PCM is this for?
  179. Software for scanning your LT1
  180. Quick ECU Question?
  181. 60# mototron injectors on a stock motor
  182. ? about OBD1 conversion
  183. PCM tune to enable lock up with a high stall converter?
  184. Low Coolant Light
  185. Need stock .CAL file for a 97 A4 Z28
  186. Ported MAF driving me nuys!!
  187. chip for a 93 z28
  188. How much h.p is the stock pcm good for ?
  189. Keep OBDI conversion or go back to OBDII
  190. Chasis Dyno tuner in Miami?
  191. 93 ECMs different for auto/Manual?
  192. SLP Skip Shift Eleminator v/s knockoff
  193. 96 File in 97 PCM?
  194. Speedo values (LT1/TunerCat)
  195. Datalogger, anyone use this one?
  196. C#.net Programmers Inside
  197. TunerPro Results (BLM & TPS Question) 1992 5.7 Camaro
  198. BLM's at idel.. Need some help.
  199. Do I need to get a tune with my mods
  200. Cant scan 95 TA with AutoXray 2000
  201. will this burner work for me (car in sig)
  202. STFT pulling fuel(too rich) wideband says lean at idle?
  203. dfi and stock gauges? need help
  204. hypertech??
  205. I think my ECM is shot ?
  206. MIL delete through wiring harness?
  207. Moates Autoprom
  208. Datamaster pro's, got a question for ya...
  209. 93 Dyno tune needed
  210. Build my own data cable?
  211. F.a.s.t. & Delteq?
  212. CATS OBDII update
  213. Can Datamaster Read Above 6375?
  214. coupon code
  215. Is the odometer reading stored in the computer?
  216. DataMaster Trial Version
  217. Need help getting inspection sticker
  218. is there anyone who has put a 94 wireing harness in a 93
  219. Where is Madwolf?
  220. help with gear change tuning
  221. wiring harness question
  222. What WideBand to use?
  223. how to upload my pcmforless tune to pcm
  224. Is It Worth It To Get The Setup for Data Logging?
  225. Need some tunning guidance please.
  226. Best free datalogging software
  227. please post your map readings with a big cam like the le2.2
  228. Good place for tune
  229. High MAP at idle
  230. Upper RPM leaning?
  231. standalone tuning 383
  232. Autotap and ABS
  233. F.A.S.T or innovate wideband???????
  234. trans swap
  235. Not your average Hypertech tuner question.
  236. Trying to track down idle problem when warm(Kind of Long)
  237. How to diagnose possible PCM problem
  238. tuning for max power
  239. anyone here use an LM-1 to tune an OBD1 LT1?
  240. Instrument Cluster
  241. Swapping the stock fuel pump for a 255 lph, will I need a new tune?
  242. Need Tuning Advise?
  243. A good tune file?
  244. Has anyone used this for SD tune with success?
  245. Latest Tunercat $EE Def File
  246. General question about Madz28
  247. Whitch Way?
  248. Quick Question-TunerCat and Win XP
  249. think my pcm is shot
  250. My mystery code...
