I need a how to on OBDI conversion
96 Impala converting from OBDII to OBDI.
I don't have to change tach drivers as I have converted to a Z28 cluster. Just need to verify that I need to short pins 21 and 22 together and then put a 2K resister to ground from those pins.
Mike
Mike
The 94-95 knock sensor has a different impedance than the 96-97. So, if you
convert your 96-97 car to a 94-95 computer you either need to replace the
knock sensor(s) or solder the 2K resistor across the 94-95 knock sensor
pins....
pins....
RUENUF
Mar 13, 2016 03:37 PM
Henson071
Dec 30, 2015 09:55 PM
tdigger9899
Sep 7, 2015 10:56 AM
