- Question Scan Tool
- PCM Tuning on 07 Vehicles
- People with 95' Computer in here!
- Datamaster How to determine HP and TQ
- Dynojet wideband where to install sensor
- changing fuel tables in tunercat
- Can someone email me the $EE Def. File?
- Which O2 sensor?
- VE Tables Question.
- fried 2 pcm's
- Gen 7 KINGS need some help !
- Low Impedance Injector Driver/converter???
- Datamsater question.......
- deleting secondary air
- OBD-II protocol/fuel level
- Looking for a reputable tuner near or in NJ?
- Here's a dumb question
- What do I need to use with VEmaster?
- Can a cable from a Snapon scanner be used for tuning with my laptop?
- a little cleaning turned into a pile of problems
- Is their a way to test the MAF sensor ?
- Predator and Torque Management
- Tuning at the track?
- Tuning w/ and w/o SuperCharger
- Trouble Codes and Senso Readings... Need help!
- Service Engine Soon light and cooling fans stay on.
- Need LT1 Edit Tune for my car
- Need FAST EFI Dashboard sensor descriptions..
- Tuning for emmissions. Where do I start?
- To scan my car with laptop
- ABS INOP but not picking up any codes on Datamaster
- Scanmaster, is it worth it?
- What Software Package Should A Novice Tuner Buy?
- How robust is a PCM? Can it survive a fire?
- I Need Datamaster 3.4.1
- Can Dyno operator/equipment cause erratic running of engine?
- Dyno operator/equipment errors with 2 tunes?
- F.A.S.T. ecu???
- how can I tell if my car was tuned?
- Best tuner program for the money?
- Can new O2 sensors make your car run leaner/richer?
- Datamaster Support
- Scanmaster O2 voltages dropping.....
- 94 OBD1 trouble codes
- Scanning software with wideband input?
- How much timing do tuned heads/cam LT1's normally run?
- Code P1680?
- tuner in LA. area
- calculated air consumption?
- F.A.S.T. Unit..making A/C work !! How ?
- Questions about full time "open loop" and logging (newb)
- help me please
- '94 LT1 scanmaster wont work!
- 96 M6 PCM into a 97 a4?
- General OBDII Code Clearing Question
- How is leaning out at WOT actually achieved???
- Recovering from a bad .bin upload?
- Need Impala SS hotcam tune
- programing a stock '95 lt1 for some more....
- Paper clip jump on my port
- Program or Scanner to monitor vital signs on 1999 ls1 ta
- Having Idle problems
- reason for intermittently going back into open loop?
- help with cut wire harness......
- Will open headers affect your wot F/A?
- BEST OBD I tuner LT1
- tune optimized for cam only...if i add heads.....
- What's with this ?
- Datamaster differences: 3.4.1. to 3.5.1.
- help
- Need Help!! Abs Inop
- looking for tuner-austin,texas
- CHeck out my scan please:)
- new tunercats question?? Pleas help???
- What tables to adjust
- troubles with freescan on my laptop
- Options for tuning
- Trouble code 61. What is this please?
- EFI live tuning
- help
- ALDL Data Transmission (OBD1)
- swapping to 3000 stall, any PCM tables to change?
- stand alone engine management
- Anyone use a moates datalogging cable?
- How Long Does it Take OBD Monitors to Be Ready?
- Startup Enrichment
- LT1 editr to tunercat question
- how to keep tranny from downshifting on dyno?
- Speedometer doesn't work
- O2 sims and rediness status
- good tuner
- Lt1 Edit Vs Tuner Cat Whats Better
- Shifting according to RPM rather than speed
- Cut out causing false knock?
- Hotcam tune issues
- Gen 7 step by step ?
- I can smell fuel at idle ? Gen 7
- Need tranny help, on a truck!
- Bracket Racing Tune Tips
- PCM issue
- knock retard -checking if false or real knock
- Gen 7 HELP !!!!!!!
- Ive got one for ya
- Scanmaster
- Open Source FreeScan
- Tuner CAT License Expired?????Help
- lt1 files
- Tuner Cat question
- What is the part number for the 94+ proms?
- Mail order tune
- tuning with EFILIVE after cam install help plz
- how much knock from RR's?
- I Need The Best Program Out There For Lt1s
- aem or other high/low aftermarket boxs
- reading Tunercat .bin need diag codes
- wanting to monitor ECU data- I have downloaded freescan but i get this when i open it
- 3000+ stall limp home problem
- DataMaster Question
- What to use to datalog lt1
- fuel pump only runs for a split second
- Accel GEN 7 & Mallory HELP
- need pin out for a 94 OBD1 PCM? where to find?
- tuner cat fan help
- madz28 tune
- New OBD1 pcm question
- cigarette lighter?
- IAC counts..
- Having trouble uploading tune to PCM
- HOW TO ERASE OBD1 CODES FROM Computer
- 96 LT1 car quit running
- Can I use an a4 pcm in my m6 if I reprogram it
- what do i need to connect my laptop to my 94z and monitor diagnostics?
- dyno tune at speed inc really worth it for me?
- LT1 edit?
- Speed Density on stock PCM
- Time for a tune?
- knock sensor
- PCM question
- F.A.S.T XFI vs. Accel DFI Gen VII?
- spinning opti backwards
- Any use keeping a malfunctioned BCM?
- Any FAST XFI Tuners in here?
- Thanks Tapout911 & Roughneck
- PCM values reset
- LTCC Install - MAF Problem
- closed loop at WOT??? log included
- SES, no cags and reverse lockout
- ECU software
- More closed loop parameter questions ....
- MAP vs KPA ...
- .lt1 for 3.42 in A4?
- LT1 and ProCharger P-1SC - DataMaster data
- need 503 tune not305
- Car dies past 1/2 throttle...sometimes
- Accel Gen 6 Users...Got a question.
- Security Light
- Need Egr Removed From My Computer!! 94 Lt1!!
- Another O2 thread ... P0133
- Tunercat ODB2 & Jet
- Need to replace PCM & key
- timing question
- Need 93 stock .bin file
- Uploading a tune
- Will Clearing Codes Off A Scanmaster Whip Out Your Tune??
- pcm for less or madz 28
- Engine data file for review
- car not starting (Ignition key sensor??)
- Maf Help Please
- Need dynotune in Denver area where to go?
- 5-pin MAF from Gen-II GM truck
- How accurate is the Datamaster 1/4 mile calculator.
- new computer 96 Z
- SLP DiabloSport II Opinions?
- Iat
- tuning for idle and maf questions
- new heads and cam in, blm's really high?
- temp sensor/guage not working after head install
- Samples of my BLM's.....
- Posting datamaster .csv log...How do I do it?
- stock rearend swap - ABS to work?
- Opti deleted PCM LT1
- Factory alarm acting up
- About to inatall my BS3 onto an LT1 using LS1 coils. Is this all I need?
- service engine soon
- O2 sensors
- What do you think?
- Does anyone still have Datamaster DA v3.4.1?
- OBD1 Question
- Alternator not charging battery, please help.
- stage II chip / hypertech for lt1.. can you use both of them?
- Datamaster inaccurate engine temp reading?
- Can someone here look at my .uni file to diagnose a problem?
- Logging wideband O2 output through PCM
- WOT A/F ratio went from 12.0 to 14.3 with no modification...
- What resistor?
- Cel Fix : cheap o2 sims on ebay
- Air conditioner and torque converter linked?
- LE2 tuning
- LT1 Knock Modules, any difference?
- Code 46 on a 94 3.4L
- Need help adjusting for new fuel injectors, have tuner cat going to the dyno
- Flooding on startup?
- injector pulse width
- Anyone selling an OBDII copy of Tunercat?
- Ecu
- Sts 05 Gto
- Whats the minimun laptop requirements for LT1 edit?
- Is there an OBDII style connector-to-OBDI Style connector cable? For OBDI LT1's
- Open Loop vs. Closed Loop Poll
- With LT1 MAF--BLMS=112/115, MAF unplugged--BLMS=135/138 at idle??
- 1986 iroc cooling fan relay problems
- O2 millivolts
- Any Potential Computer Swap Problems Here?
- Tuning Noob ??????
- Has anyone used the OBD1 traction control timing retard for n20/etc?
- Header leak causing spark retard?
- Not getting spark in LS1
- No crank after tune...help!!
- OBD-1 with cam?
- OBD II Diagnostic Tool Recommendations?
- MSD Box problem
- Weird problem
- tuning for new injectors
- changing tire size
- Opti?
- Having problems
- O2 mV
- Freescan work with USB?
- 98-02 Firebird Cluster in a 93-97??
- Completely happy with AKM's USB cable!
- LT1 Edit???
- idle
- Software just for oil pressure in trans
- Lterm and Sterm not coming on
- need help guys..
- CC306 tuning...
- A guide to Tuner Cat
- Anyone got these definition files? 93,94-95 LT1?
- Bin file question.
- Madwolf are you out there??
- PLEASE HELP What to order with tunercat??
- Will the PE vs RPM table be used in open loop?
- Stumble @ 2000rpm-> Then Fuel Pressure Drop
- How do u tell if u have an obd1 or obd2 Comp.?
- Tunercat Speedometer Recalibration
- trans am missing
- need a program for blown m6 94 model
- DTC 43 ESC Failure???
- MAP is reading way too high
- Idle issues after A4 to M6 swap
