anyone have a true fix for the odb 1 high stall no shift problem?
Old Feb 15, 2003 | 07:52 AM
fastz28's Avatar
Question anyone have a true fix for the odb 1 high stall no shift problem?
well, my 2800 stall isn't going to cut it w/ the new engine so I'm trying to cover my bases and find a fix for the shift problem before I have it (I figure w/ my luck I'll get it and more lol)
'94 in the sig, novice lt1_edit user
thanks in advance
Old Feb 19, 2003 | 07:05 PM
Dan K's Avatar
It seems that the "common" fix only works about 75% of the time.
If you have problems with it once you change, the solution has been given by a couple a people in this forum.
Do a search, you'll find it.
Old Feb 20, 2003 | 09:26 AM
dabear95's Avatar
Dan, I have been searching and not able to find it, can you help me out?
I'm installing a converter soon...
Old Feb 20, 2003 | 05:31 PM
Dan K's Avatar
You have mail.
Old Feb 21, 2003 | 08:00 PM
brokenz's Avatar
I wouldn't worry about it until after the install. I'm running a 3400 stall Vigilante in my 95. Just had to lower the WOT shift points some.
edxiel
Jan 24, 2015 07:40 PM
97SSdude
Dec 31, 2014 07:43 PM
Cam's maro
Dec 28, 2014 09:30 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
