- remove speed limiter?
- Transmission DTC 22 & 72 after hard launch & car wont shift
- At 4200 the motor lays down - sanity check
- O2 sensor question
- Small knock issue
- anyone have a datalog for an le2 setup
- VEMaster author
- Accel Enrichment
- Tunning Help please
- Best Tuner?
- map not 100kpa at wot
- Smooth graphs in tunercat???
- barometer changes during test run
- Tuning a 93 lt1
- Ed Wright
- Anybody have a similar combo (cammed and blown).
- 95 Z28 230/236 M6 ported heads file
- setting shift points with diablo tuner
- Unexpected datalogs when at WOT?
- hp difference, conersion or tuned OBD-II
- old power programmer plus
- Cells 6 and 10, need help with driveability.
- Tunercat guys
- stay with obd2 or convert?
- PCMCIA to RS232 adapter
- Programming for different tire sizes?
- took away fuel in VE tables and now running richer
- LTCC and Raptor Shift Light
- OBDII Plug in Software?
- Is it normal for the LT1 map to cause code 33 on startup? after bat unplugged?
- Quick tunercat question (did search)
- FAST / C-Com WP software...
- 383 LT1: WOT at Idle, BLM=128... but not when off the Brake and rolling?!?
- Need Diagnostic Tree for OBDII Code: P0171
- M6 PCM controlling TCC?
- 93 tuning software available?
- Is there any advantage to LT1 Edit over Tunercat (searched already).
- 94 camaro 94 caprice computer
- OBDI LT1, Tunercat, big cam, right bank running very lean
- DataMaster vs. Freescan
- 1336 code after longtubes etc
- Changing tune for cube increase question....
- Troubleshooting poor MPG - What to look for in Datamaster?
- car is really really lean at part throttle
- TC, WOT tuning a/f - thru the MAF tables right?
- question on chips
- Need 94 M6 stock tune.
- I need a stock tune for 95 M6 Z28
- how often do computers go bad??
- Speedometer
- Anyone running the Knock module with Gen 7?
- ignition
- Need some Tunercat help for OBD1.
- PE Delay?
- lt1 running like its missing
- LT1 edit help
- '93Z reprogramming
- obd I obd II
- idle rpm
- Datamaster Qs?
- LT1 edit or Tuner cat
- Will a 6 speed car run okay with an A4 program?
- Where to tune?
- New Issue - DTC 41 "EST OPEN"
- Constant knock retard, logs inside
- Check Guages light
- Mad props to Madz28, Thanks Ion
- please help senser losing vacume
- engine & wiring harness swap questions!!
- Pro scan
- More OBDI and OBD2 stuff
- quick question need help fast!!
- airbag light
- Sending in to Texas Speed...
- OBD1 vs OBD2 - What would happen?
- Which way does what in the VE Tables?
- obd2 tuning
- mail order tune vs. DynoTune
- Worried about tune
- Closed Loop Idle tuning in SD Mode??
- tunercat?
- Getting started in self tuning... Qusetions...
- help please. needed very badly ready to send car to savlage yard!
- Power enrichment mode for 95 LT1?
- differance
- OBD1 limits
- Which ECM's work with our cars?
- ecm location
- TEC 1 electromotive and usb serial adapters? Injuneer??
- inline to square plug IAC question
- If you have LT1 edit please read this forum!
- Map sensor ?
- Data logging
- Hypertech Error
- A different kind of EGR question - PCM related
- Sources for AN28F512 chips?
- Wideband question
- I need help with the diablo tuner BADLY please help
- Info needed on how to ZIF socket PCM and where can I get a kit to do it?
- Flashing PCM and it failed to establish communication, now car won't run??
- camaro 1997 side Fuse Panel diagram-Anyone have a pic
- msd digital 6 box
- Headlights will not turn off when car is running??WTF-Help
- Scanmaster
- Spark retard and knock count
- new tune, now car boggs off idle
- new tune
- Stock program needed
- disabling egr in PCM - I can leave it installed and connected right?
- Average Long Term Fuel Trim
- lt1 edit help
- TunerCat obdii vs lt1edit obdii
- Spark advance table for hotcam/cc305 or equivilent? Share yours?
- Dyno Tune Wideband
- Whats causing my 108 blms at idle?
- those using LS1_edit, where do you get the gms air/cyl data from your scan tool....
- can an Ed Wright locked PCM be reflashed with tunercat?
- Z06 Maf
- TunerCat for '98
- 95 PCM question
- Adjusting idle with Tunercats for a M6 car
- How to tell if your 93 Lt1 has a stock program
- 95 Lt1 Xdf
- tunercat
- weird 94 formula abs inop problem
- LT1 Definition file
- Headlight Trouble
- WOT Tuning, Spreadsheet attached.
- ABS Light comes on then off! Please Help
- 3.23-3.73
- Dtc 67
- Need Gen7 wiring help
- Gen 7 pro's NEED HELP !
- Electrical problems on 94 Z28
- I need a Stock LT1 file
- here is my datalog. can anyone decipher it for me..
- AIR/EGR delete question
- Low coolant sensor
- LT1 tuning
- Low Oil Light
- readiness test
- need help
- Sure is nice to have an electrical engineer friend
- HP Tuners VATS Security Light Question
- Dynojet Wideband O2 Sensor RPM Output Inop
- a/f ratio hookup
- People with wideband setups
- First Time tuning a 91 Camaro
- Have 3.73s, speedo and odo are off by ~15%
- Cables for OBD1
- PCM 4 less
- Keyless entry programming problem. PLEASE HELP!~
- who is good at tuning a 93 speed density..
- Tuner Cats larger injectors
- 99 ls1 deleting codes
- Someone to reflash my hpp!!!
- freescan not working?
- Any way to check codes on my obd2 lt1 without software?
- Do any free obd2 scan programs work with the tunercat hardware?
- ?'s about laptop, just got one
- Repining the C100 Block
- 5" Tach
- Tune out part of ABS?
- Tunercats question
- Dtc 42 ????
- What is your favorite obd2 datalog program?
- VERY disappointed with Bryan Herter Customer Service..
- Computer died the other day, but now its working again????
- "Invalid Response from PCM"
- Cylinder Volume in Tunercat question please...
- PCM no read
- Best place to buy AC Delco 02 sensors?
- LE2 383 Idle AF
- rs32 or usb cable?
- differance between a4 and m6 tunes?
- o2 sensor ?
- stock 94 m6 tunercat file
- Will a caprice OBD1 from a 94 work on my Z?
- ? about LT4 KM and Madz28 tune
- OBD I issues on 97 LT1
- Need a stock 94 tunercat file
- TCC lockup at 93-100% TPS. Is this the stock flash?
- Ses Light Question
- 52mm TB, Increase Trans Line pressure?
- Drops in RPM when coming to a stop???
- Guys running FAST XFI with LT1 cars with stock gauges???
- BLM's on the rich side
- Stumble/Miss under load... Any suggestions?
- scanmaster not working
- 108 BLMs...Any ideas?
- Dead computer
- Plx R-500
- PCM Identification
- Madwolf....???
- hey madwolf, or anybody, ecm wiring question
- tapping pin in ecm help
- How long does a code stay in the computer?
- Abs Inop
- How much for a good tune
- Datamaster
- can tune PCM to pass emissions on 383??
- tts datamaser and tunercat ????
- Shift point problem.....
- Madwolf....
- LT1 edit not connecting to pcm
- Which wideband 02 meter is the best for me?
- changing gears
- Air pump question on lt1.
- Datamaster reveals MSD rev module kicking in early?
- Pcm Question!!!
- Tunercat equipment ?s
- LT1 Edit Cable Only?
- Really tough nut to crack here on SES light
- Hypertech Power Programmer III Q's about shift points..
- help with lt1 edit
- First time tuner cat
- Help with lt1 edit
- Ecm Pin Help
- OTC Genisys programming
- obd ?
- big block fi system
- 1996 Z28 Throttle Spring Problem***
- How tunable is TBI?
- hypertech PTM help!
- profile swaps in lt1 edit
- adjusting A/F ratio with Tunercat?
- mail tune and hypertech ?
- Guys with bigger cams and datalogging capability, post your MAP value @idle please
- msd opti
- Texas Speed Tune
- DTC 33 immediately on new setup startup, can someone look at data logs for me?
- orlando florida 95 lt1 tune help!!!!
- Shop Version LT1 Edit and Laptop 4 sale..
- new pcm for 96 z28
- Dtc 41 & 42
- Obd2 tunercat and knock retard questions..?
- Dtc 51
- Beat surge by disabling closed loop, now what?
- Looking for someone with cable in Baton Rouge
- pcm for less??
- What is the formula?
- No communication with car
- Tuning Help - Look at my Dyno Sheet
- Tunercats
- changing gears
- Tunercat / CAT WinFlash question
- Any tuning chips/programmers for a 3.4 V6???
- possible electrical problem
- Quick low oil level sensor question please...
- What will I gain
