1.6 RR's now lean on throttle tip in
I'm getting random lean backfires when reving the car from idle (car idles at around 1500 rpm in neutral while coasting at times then settles down but that's a different issue) I can watch the O2's drop down in the low 60 to 90 mV when this happens. I just installed 1.6 RR's. I also have:
30lb SVO injectors (used Christian's SVO offset)
Headers
NOS 58mm TB (for dry setup)
3000 rpm stall
Other than that it's a stock iron head Impala SS.
I have new O2's sitting in the trunk - I've not changed them and car has over 100K - don't know if previous owner ever changed them.
Also have to slot the TPS sensor so full throttle doesn't throw car into limp home mode so it's .20V at idle
I can email someone my file if they wish to check it out.
Please help!
Mike
Headers
3000 rpm stall
Please help!
Mike
Well, it doesn't matter now...
Blew my 4L60E last night on a nitrous pass.
Car is now at the shop for ported/polished aluminum heads and 224/236 - 114 LSA Comp Cams LT1 Xtreme nitrous cam along with a new tranny and transgo shift kit.
Mike
Mike
