- getting set for tuning
- Update To My Split BLM Issue - Suggestions?
- How did you route your wideband wires into the car?
- Reverse Lockout Malfunction after new Master
- Help with choosing tuning platform
- oil temp and fan functions
- Can ABS light be deleted from PCM?
- OBD II to OBD I, auto trans question
- Wideband o2 bung question
- looking for obd1 lt1 cam tune
- my camaro
- Any way to lock my idle BLM's only? Or stay Open Loop at idle ONLY?
- tuner / scanner
- ideal PCM for forced induction setup
- freescan help needed
- EFI Tuning series in "Engine Masters"
- PLEASE!!I need a bin file for 30lb ford svo injectors
- BLM question Park vs. Drive
- Cluster not working
- Running rich codes PO175 and PO172
- Nitrous Timing retard with traction control?
- FAST dual wideband O2 through TTS Datamaster?
- Speed Density tuning
- ALDL port not communicating
- Pulling Codes
- autotap newbie
- Oxygen Sensor heater monitor won't set ready
- normal data from sensors
- Car Stereo Security
- am I on the correct path?
- Question on OBD II datalogging software
- freescan "hiccups"
- datamaster help
- Can someone look at my logs (BLM 16 & 18 issues)
- Need driver for WOT tuning cable
- MAF Voltage 3.59?
- This sucks...Please help...
- MSD Digital 6, Have it Rebuilt or Buy new?
- New to tuning - Dont understand my BLM's ....
- BLM's and Fuel Trim Multipliers
- Are SES codes stored after light goes out?
- Anyone ever use VE Master?
- Need a real expert to look at my Datamaster File
- tuning Q
- How do I Calibrate my MAF?
- AutoTap Sample Rate
- cam lope at 45-55mph
- O2 sensors full of soot,can i clean them?
- STerm counts and LTerm counts
- automatic pcm in a manual ???
- security?!
- Can't Clear History Codes (2 A/C Related)
- Obd1 pcm
- obd-2.com?
- siemens 80lb injectors tuning help!!
- Fuse panel for 2000 camaro
- wiring pinout for drivers side engine bay harness
- Retrofit question. I think I may have something not 100% right
- What gives an idle the lope?
- FreeScan vs. DataMaster ?
- Car flops in and out of closed loop?
- AKM Cable issue...or something else? Dropping ALDL connection during scans
- motor fires up with starter fluid but no injector pulse
- Atlanta Area Emissions
- Finally got some line pressure readings after rebuild.and.
- Datamaster Log 95 Z28
- TunerCat Idle air/fuel adjustement (BLM)?
- How to test O2 sensors heating circuit?
- need prog file for ecm for ford svo 30lb injectors 1994z28 6sp
- tuning for MAF size
- MAF problems
- Freescan won't begin a CSV File!!
- What version of Windows for TunerCAT?
- Datamaster vs. Stupid cop
- Wide BLM split at cell 16 & 18
- DE-tuning ??
- Does Freescan need engine running to scan for engine codes?
- Speedometer way to low...
- Codes 29 and 48
- Transmission tuning question
- Is a tune a good idea yet?
- Could some look at my freescan log??
- Tunercat O2 Rich/Lean Swing Threshold?
- Which OBD2 O2 sensors are not used with OBD1?
- My DFCO doesn't work, why???
- Is WOT Always Open Loop?
- has anyone ever "made" your own pcm wiring harness
- Unusual Lean Condition at Idle
- pcm
- Cable
- PCMForLess.com FREAKING OUT - To Much Work - Maybe Pick Someone Else?
- PCM Detection Problems (2 New PCMs) Some Comunitcation?
- 95 Formula tunercat problem
- PE % change to Fuel/Air ratio vs coolant temp
- OBD1&2 Scanner
- Cam Surge
- two different tuning softwares on same laptop..Any problems?
- code29 Can anyone help with diagnostics on this .
- AKM cables not responding...
- ? on tunercats
- Bin file for LT4 needed
- FP vs BLM
- EMERGENCY!!! MAF question
- hitting rev limit before shift, why? tunercats
- Any Mail-Order 2 Bar Tunes?
- Tuning Q
- Tunercat - Compbin - Any good?
- Why would the cylinder volume be off?
- cold start up closed tps timing
- question about fan setting in tunercats
- question reading tune with tunercats
- Looking for a stock 94 A4 camaro tune file
- LT1edit question
- BLM Locker
- No PCM Detected?
- LT1edit and emissions
- Is there a place to get tune files for tunercat?
- Overheating and High Idle
- Jet Dynamic Spectrum Tuner for 96-97 LT1: Opinions
- 4l60e trans tables in TunerCat
- DFCO help and few other ?s
- Cheapest place for Datamaster?
- Which PCMCIA to Serial Adapter Card Works?
- How many have had Tunercat problems? Thinking of buying
- Leaning out at WOT and random at part throttle... tough problem
- FAST Question
- I need a base tune, accel, gen7 who can help
- PCM Junk After Succesful Flash?
- so whos runing e85
- where to buy a cable for tuner cats
- Can RPMs to the ECM be wrong?
- Tell me what is wrong here?
- 93 LT1 tuning help!!!
- inatalled new engine. mph on dash raises with eng rpm
- Question about VEMaster
- Purchasing LT1 Edit
- Fan problem
- car has a draw problem
- traction control
- Thank you Trifecta
- BLM Locker Programs 16159278
- anybody have obd1 cc503 to compare?
- tuner for adjusting timing?
- My 383ci LT1 has been running like crap.. V. injectbank PW 1&2 are way off
- To everyone that has fried their PCM with a USB cable.
- Pushing panic button (LT1 Edit OBDI) please help
- Another dumb question about TCS
- 1994 harness on a 1997 T/A
- Any Dyno tuners in Central - Southern California?
- Can i go to the strip with a P0336 code?
- Anyway to defeat the P0335/P0336 Trouble codes?
- False knock?
- Freescan data problems
- Part throttle fueling...........
- usb -serial adapter cable driver problem
- What's the car do when it hits rev limiter?
- Gauge Connector
- fried PCM?
- Transmission Settings for Dyno Run
- High rpm issue
- Where's the false knock coming from?
- tunercat with mark 8 fan
- Looking For A Tune To Start With (383, LE2, 236/236, M6, 58MM TB, CAI, Flowmaster)
- Swaped stock radio in 99' TA aftermarket and now the A/C does not work. What to do???
- Decreased cranking duration
- LT1 Tune Help. Fresh 383
- pcm bad?
- WOT Ignition Timing
- Question for tuners, Hypertech + shift points.
- 93Z computer diagnosis
- LT1 tune
- LT1 Hot cam fuel & Spark tables
- Low idle at cold startup
- Multec 42# injector offset table???
- GM or Vetronix tech 2 question....
- Went to 75lbs low ohmes injectors now hard to start when hot
- In need of stock lt1 M6 tune
- LT1 AF ratio off the chart
- Street Manners
- lt4 knock module
- Changed Fuel Injectors no start
- Anyone know where these PCM Pins goto?
- Scan error codes
- OBD2 to OBD1 do pins need to be changed around?
- OBD I codes?? tuner cats
- O2 sensor question
- who can do a mail order tune on a 97 firebird PCM?
- Getting started....usb or serial??
- TPS code
- Can 96-97 ECM be programmed with OBD-1 Tune?
- Lean! on startup.....
- Big Cam, 107 lsa need somewhere to start!
- Weird BLM counts?
- In Need of a Datalog Reader
- BLM Locker ?
- CEL came on and I got this code
- OBD II... I'm a newb. HELP!!!
- plz check datalog :(
- lt1pcmtuning.com's mail order tuning experience?
- Short idle log
- 2 Probs, 1. knock sensor; 2. A/C Sequence of operation
- O2 sensor help
- going from a obd1 to a obd 2 pcm
- Need some help... OBD2 port isn't powering up?
- Tuning for a 114lsa cam?
- Another VATS issue??
- Question about Pulling Codes on a 1994 Z28
- VE table for LT4 heads/intake and hot cam?
- Running the stock PCM past 7k rpm
- O2 Rich/Lean Swing Threshold
- Understanding DataMaster
- LS1 engine computer and harness
- OBD-II Scanner Options?
- wideband output to ac pressure port?
- soldered eproms which ones are they?
- pcmforless vs mad z
- runs horrible in closed loop great in open??
- After market ac wiring ?
- Lt4 knock module, Transmission matter?
- Car runs like crap after converter swap???
- autoxray vehicle not rersponding when clearing codes
- code 83 TCC PWM Solenoid Circuit Fault on my 1994
- why is there 3 serial data terminals in port? OBD1
- what turns the ac pump on? Electrical?
- Fan temps in tuner cat
- Help me decided...2 bar or Maf 600+rwhp
- application EDIT_LT1
- VE master on windows 2000?
- New Gears, Change Shift Points?
- Tuning with a Netbook?
- autoxray 3000 scanner work for 94 OBD1?
- Freescan will not set up, anybody have this problem?
- More ABS issues
- Need help making VE table
- LT1 Edit question
- New to This, and Looking For Help
- 93 computer upgrade
- Tuner cat BARO RESET?
- New Injectors... What's are the PCM changes needed to make them work?
- Preset tunes for Tunercat
- T56 conversion CATS
- Possibly bad VSS?
- ABS code scanning
- stock injectors
- No Check engine light.. EVER!
- Needs some answers!!! (stock computer)
- Engine Swap and FreeScan
- PCM recieving no signal and no fuel pump?
- LT1 TCC Forced Lock Speed at WOT
- 96 PCM in a 94 Z28
