- Installing a Knock sensor light ??
- tried search: testing O2 sensors, which wires?
- PLEASE: Help me out
- Need stock 95 Z28 bin file for M6
- P0135 O2 heater causing SES... any ideas?
- SES and 5 codes,
- How to tell if I have a reprogrammed chip?
- programming ?
- 94 computer switch with 97
- Better to tune with the stock MAF maxed? Or with the new LPE MAF?
- buddies mustang gt vs. my ss
- SES after catback install
- Aeroforce Interceptor Gen II OBDII Gauges Available and on Sale at MarylandSpeed
- ODBII LT-1 Edit A4 Questions
- best tuning software for a 95?
- VATS & lt1 edit??
- OBDI Codes 23 & 48
- Which scanner???
- 95 and 97 lt1 ecu difference??
- Getting rid of spark retard.
- lt1 computer???
- madz28.com?
- Anyone need any small changes?
- No MAF? Good or bad?
- Car is throwing two Crank Position Codes - P0335 & 6
- Need stock 94 A4 .bin and have questions
- Security System Issues
- 94-95
- Keep hitting the rev limiter
- Best program to datalog obd2
- 95 lt1 fuel adjustment
- Please help diagnose some problems
- Power programmers who's is the best
- TTS Mastertune anyone?
- P0300 ( Random Misfire)
- Thanks Shoebox!
- not sure if this is the right place to post ?
- Locked HPP
- Is there a way to test a PCM?
- Looking for detailed descriptions of how OBDII PCM's do EFI
- code 43 (esc Module or Sensor circuit problem) i am new at this!
- Basic scan and tune
- Reprogramed ECM, now speedo is spazing
- What benefits would I gain by switching my setup from a single bar map sensor to a 2?
- Need help with switching from a 1 bar map sensor to a 2 bar...
- ALDL Software for 1994
- Software for ECM programming?
- 95 LT1 383 tuning help
- Pcmforless, or madz28?
- P0172 Trouble Code (system too rich bank 1)
- Help with some error codes please!
- can the guro's look at my freescan log?
- autotap logs requested
- Disabling/modifying lockup.
- knock sensor
- flashing PCM outside the car
- is there a way to test the obdII port
- High map code after BLM locker and weird rpm incrementing
- LS1 PCM on LT1.
- What cable do i need?
- Re-Pinning 9354896 pcm
- Hypertech does not say what to do
- Rear 02 Sensor
- Tuner help
- Interceptor Scan Guage
- New Chip for a 1993 Z28
- LT1 and a rear dist.
- Props the Bryan at PCM for less.
- Can't read PCM with BenchTop Harness
- security light
- EFI Live: Request for Information please
- 22 Throttle Position (TP) sensor circuit (signal voltage low)
- check engine light
- new to tuning..
- Mastech vs. AKM vs. Moates.net Cables
- 95 camaro tunerpro
- help tuner pro?
- Running a 94 4L60E with a 01 411 ECM
- Spark Retard Question
- LT1 and HPTuners
- How to Fix Stall Wall?
- Nitrous tuning
- Maf Sensor H.p. Max.
- Removing air bags and deleting air bag light
- ghost codes
- Stock Lt1 A/f Ratio?
- Got My Codes Read and need some help...
- Which painless harness to use
- 150 MPH cluster
- Injuneer, can you look at this datamaster? 383 problem
- 87 ss monter ecm and prom work in place of a lg4 set up?
- Tuning out trouble codes.
- how to set idle rpm in tunercats?
- code P0153
- Will a '95 computer work in a '94?
- lt1 into another car
- LT1 edit hardware
- Any LT1 Edit Tuners???
- error 51
- ECM troubles
- Lt4 knock module?
- 2001 catalytic converter recall
- Stuck in cell 16 128/128 at Idle or at any time TPS=0
- Help with FAST and a FastTrack harness...
- scanmaster or datamaster?
- need help with shift points
- Speed density theory and 2 bar tune
- why the 1-2k rpm backfire look
- Tunercat
- OBD II all new cars?
- VATS dissable on 96 grand am
- DFCO information???
- Very strange situation
- Knock retard (4*) when I stomp on it
- 1997 Camaro SS / MM6 program
- Can someone take a look?
- Changing Park Idle Rpms
- Iat and stumble question
- Latest Tunercat EE version?
- HELP!Car won't idle very well in gear when cold!
- Modifed 95 Camaro z28 A4 bin files with 323
- Failing ECM?
- Stand Alones
- IAC follower is too long
- Anyone using megasquirt on an LT1?
- Speed density tuning
- 87 camaro help!
- Help
- Problems with new computer
- PCM on a 1996 Grand Sport hot enough to purn you
- PCM Backward Comptible?
- found a Code forum..
- 3 fried ECM's in a row! What's going on?!
- lt1 pcm
- 98 ls1 tunning question
- flashing my PCM
- th350 and automatic pcm
- is there a way to clear the pcm?
- EASY MegaSquirtII install? 9 wires. . .
- disabling knock sensor
- Injector Duty Cycle..cant go above 60% with new injectors!
- L69 prom work in stock 86 LG4 ecm?
- Where to get LT1 tuning software?
- 93 PCM basic info ?
- Pcm tuning for idiots
- ls1 timing vs lt1 timing
- Idle problems.Need help!
- obd2 tunercat/Dynamic spectrum tuner
- ses codes
- 94 block 93 pcm???
- Lt1 Edit version 2.0 vs. 2.2?
- Help Interpreting Scanner Data
- Password
- what is wrong...O2s all over in PE
- new to tuning
- Will a 95 jet module work in a 96????
- Easy Tunercats question
- Recomended tuning options
- Running out of fuel..but shouldnt...
- 3.42/4.10 gear change
- Possible 93 PCM causing me Problems!
- Another gear swap, shift point thread...
- dyno tune with predator?
- Looking for beta testers for PCM programmer
- What are the PE tables?
- 4th gen keyless on 3rd gen?
- Quick pcm question
- O2 with leaded fuel
- 8* knock retard at 4200 RPM
- Can somebody explain my dyno graph to me
- Need wiring diagram
- Is their any place in NJ that I can take my car to get dyno tuned....
- supercharged pressure side maf tuning problem
- Limp Mode?
- Stock M6 programming
- datamaster question
- Accel Starting Problem
- Forcing Open Loop - OBDI/Tunercat
- ECS code 43
- ALDL cable issues
- LC-1 Xd-16 and loging with a stock PCM
- Megasquirt vs. other aftermarket ECUs...how does it compare??
- In need of an LT1 file
- Couple questions regarding MAF
- lt1 edit files or scan data
- auto file
- Got datamaster and a old lappy..
- Can I get rid of the computer in my 81' Z28?
- lt1 computer options
- can i delete datamaster from laptop after free trial?
- Interface Cable problem
- speed density tuning
- 1997 Camaro 3.8 - need help with plugs flooding out
- New pcm
- Has anyone ever mapped out the OBD2 LT1 PCM program?
- help with a4 downshift
- can you guys take a look at my freescan log?
- ECS code 43
- car cutting out
- running rich
- speed density question
- Moates.net tuning/datalogging cable . help needed.
- 30lb inj v.s 24lb with tunercat? new tune ?
- tuning
- General Tuning
- Where is the Radio Fuse?
- OBDII to OBDI Help needed
- what needed for LS1 tuning?
- AFGS on blown a blown 355
- Newbie Question
- Trouble codes & comp. questions
- pcmforless vs. madz28 vs. hypertech
- Hypertech tuning problem
- Scanmaster DTC 63
- LS1 scanmaster works on my 97 LT1
- What trim cell should I be in WOT??
- On an OBD2 LT1 car, what happens if a rear O2 sensor is bad?
- Looking for a .bin or .lt1 file
- most hp with stock pcm? are they limited?
- Tuner Cat Help?? What Table?
- Who makes ScanMasters, I have a question
- Injector flow rate question
- I need computer files!
- any program i can run threw my laptop?
- REMOVING cats on 96 lt1
- Funny VE table problem 94 LT1 in SD mode
- 96-97 obd 2 motor in 94 ta Q's
- datamaster help please
- lt1 obd2 tuners in/near nashville TN??
- LT1 Edit
- LT1 tuning problem? datalog inside
- ABS INOP and BRAKE light???
- Please,Help! Anybody in here know how to Reset A 97 Hypertech Programmer Plus??
- Tuning w/email tune OBD1...
- tcc lockup disable
- Easy TunerCat questions
- tuning OBD1!!
- sixspeed to auto
- What prog do I use to edit.
- tunercats no longer available....
- can someone look at my scans please?
- hand held programmer help
- Which is data port on 95?
- Help...please
- 94/95 Pcm ?
- GM Wiring Diagrams & Pinouts
- input needed
- PCMforless is it worth the price
