PDA
View Full Version : Computer Diagnostics and Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 [29] 30 31 32 33 34 35 36
  1. looking to do my own tuning??
  2. 370+ rwhp tune help
  3. speedo and tach problem, related?
  4. BLM boundaries HELP !
  5. Any reason not to lower IAC Park position?
  6. timimg advance
  7. auto-tap question
  8. Thats it I am taking the plunge... Tunercat? help please.
  9. Need copy of Drag2003 demo
  10. Could use some help.....
  11. Tunercat Scaler
  12. Does F.A.S.T. make your car emission illegal?
  13. Simple way to lower BLMs?
  14. Tuning Help plez
  15. LT1 edit and real time tuning...
  16. CC306 and tunercat ?
  17. Activation wire
  18. How do you switch your PCM to the performance tables?
  19. Need help with TABLE in tunercat
  20. VE Master results
  21. Where do i start?
  22. ccsmotorsport
  23. madz28.com?
  24. 3800 PCM Tuning
  25. What's needed with Tunercat to program?
  26. P0102 Mass Or Volume Air Flow Circuit Low Input
  27. 60mph in 6th gear vibration
  28. Someone help!! Starts up but turns off in 1 sec
  29. Installed Granatelli 85mm MAF. Need to program PCM??
  30. Need stock bins - ASKW, ASKU, BDLF, BDLD & BDLC
  31. Stock 02 shift points in rpms?
  32. What cable should I buy to scann and program my comp?
  33. oil temp settings in tunercat
  34. Tuning w/ Tunercat
  35. Can a car with an LS1 edit program possibly fall in and out of tune?
  36. 97 PCM pin outs
  37. LS1edit to bin
  38. Datamaster log, please help
  39. 93 Tuning parts
  40. Tunercat free eval question
  41. BLMs 160/160 at idle
  42. speed limiter
  43. Need help deciding ECU upgrade path..
  44. Diagnostic Software
  45. Ok..datamaster working with F5U103...LT1 Edit no go?!?!
  46. Datamaster File inside, help me plz
  47. Is this in any way remotely possible? pcm chip related
  48. idling/running rich, causes bog on heavy throttle
  49. VSS Buffer?
  50. what shift tables and tcc tables to use...
  51. Can I make my car stay in open loop?
  52. What all is Needed??? OBD-1 2 OBD-II????
  53. injector setting seems WAY off.
  54. question about tuning with timing
  55. who has split idle BLMs b/c of a cam?
  56. Tuner Cat: Idle % Fuel/Air Table Question
  57. Car stays into Open loop... could this be the work of PCMforLESS?
  58. byrans fix for obd1 stall
  59. idle at 65 KPA....what in the world
  60. What kind of wire does AKM use for the cables?
  61. Low end tuning and cam surge.
  62. everyone running with no cat's in here
  63. leaning a/f ratio ( mass air)
  64. LS1/LT1 Edit
  65. Need source for packard metri-pack connector
  66. Injector offsets
  67. 94Z for my son
  68. Looking for a LT1 bin file w/ the follwoing
  69. Power Programmer?
  70. OBD1 & Maxing out MAF
  71. Wiring in FAST ecu
  72. Question about LT1Edit log file data
  73. Why does the A/F ratio @ WOT table zig-zag?
  74. Anybody get to look at a stock LT4 file?
  75. How to change Air/Fuel mixture in open loop
  76. Autotap
  77. Open Loop Obd2 Lt1 Tunes?!!?
  78. Need a Stock TunerCat File for 95 A4 3.23 Car...
  79. Need help tuning in the NW Indiana Area
  80. Shift tables 95 a4 3.23
  81. What are some tuning tips for Stock then a Hotcam,bolt on car? 2 part question..
  82. New PCM
  83. Idle tuning...
  84. Wiring my drag car
  85. (ATT. ANDREW)Erasing 93 EPROM Chip question...
  86. what the hell?
  87. What causes PCM to go back to open loop after in closed loop?
  88. SES and CAGS
  89. Question about valvetrain noise Madwolf!!
  90. Anyone have a stock 3.42 A4 Tunercat BIN file?
  91. Air/Fuel diagnosis help
  92. Help!!
  93. Strange DataMaster reading - and I mean strange
  94. Need Help Fast!!!
  95. how much to alter MAF tables by for descreened MAF?
  96. idle/air fuel ???
  97. Performance chip?
  98. cylinder balance question, thanx.
  99. how to compensate for cam surge? HELP!
  100. SES Light
  101. min spark advance v.s rpm(tunercat)
  102. Having Trouble Pinpointing Problem
  103. Help tuner cat security viloation?
  104. Predator users inside
  105. No serial port on the laptop... USB?
  106. tunercat help
  107. Air
  108. Crank A.I.R.
  109. Spark Advance on 383
  110. Problems with andew's aldl converter
  111. how to lean out a/f ratio( tunercat MAF tables)
  112. Stupid Laptop wont stay connected..Plz Help!!
  113. Easy Datamaster ?
  114. best editor
  115. LT1 edit terms
  116. tunercat/LT1 edit ???
  117. Would moving to a lower altitude cause the engine to run leaner?
  118. OBD2 code help
  119. VEMaster???
  120. PCM Repair after intterupted programming?
  121. Need OBD2 program again...
  122. What to use to program?
  123. Looking at buying LT1/LS1 edit.....
  124. OBD1 conversion kit, where to get it??
  125. can't read tables window(tuner cat)
  126. LT1 edit and EGR
  127. Tuning question on new heads
  128. Computer ???
  129. CAN someone look at my DATALOG?
  130. Tuning tips?!? Help me out allittle here!
  131. anybody know how to enable closed loop ONLY after 1000 rpms?
  132. files for 58mm TB
  133. Software
  134. speed limiter
  135. Need Help With Tuner Cat!!!!
  136. need cheap computer programming
  137. can someone explain to me how to diagnose misfires on OBD1 computers?!?
  138. Ltrem fuel maxed out @ +25
  139. car has black soot on bumper, how to stop this? w/ tunercat
  140. How to get LT1 computer to work after accident
  141. OBD1 high stall problem
  142. running on 6 cylinders
  143. how to set up idle tuner cat
  144. Datamaster help ??????
  145. 93 Won't run right with piggyback adapter. Help please!!!!
  146. Obd Ii To Obd I Conversion
  147. logfile in LT1edit
  148. LT1 edit and delting EGR/AIR
  149. car gets too much knock
  150. Hesitation diagnosis with Datamaster needing help!
  151. I want to start experimenting with my car...
  152. Clicking underhood while programming
  153. Fuel pump engaging when trying to reprogram?
  154. speedometer wrong. ooops
  155. Auto Xray readings...
  156. newbe
  157. Request for information on Aftermarket ECM flashing and possible consequences.
  158. Trouble with car, bucking/hesistating under 2000 RPM DM logs inside
  159. grrr...MAP readings:code 33 on Scanmaster, also Lean o2's both sides..need some help!
  160. Question about tuning
  161. Hesitation, Won't accelerate. Scanmaster readings inside
  162. What would cause this miss?
  163. TTS Datamaster problems
  164. is my 95' obdI or obdII?
  165. Engine idles rough and stalls
  166. Missing link -OBD1 files
  167. EGR and LT1 edit
  168. computer programming????
  169. O2 sensor readings in TunerCat
  170. BLM's are Low and Car Running Lean on Right Side??
  171. Datamaster Problem
  172. Looking for a code listing
  173. ECM Constants
  174. Interesting thing happened??!! Tunercat!
  175. Why dont I have a check engine light?
  176. How to Raise Target Idle RPM????
  177. ? with gt 100 and detonation
  178. Speed Density Tuning Programs Help
  179. Rough Idle/Stalling Datamaster File
  180. TPI sd vs LT1 MAF?
  181. Need help FAST PLEASE!!! PCM's keep dying during flash
  182. 1 wire to 4 wire o2 conversion question.
  183. 1995 Z28 with obd1 or obd2?
  184. Computer Diag Listing/94 LT1?
  185. software glitch in lt1edit?
  186. Need help with a code
  187. Who can flash my extra PCM so that I may remove my current one that has LT1 Edit?
  188. Can i use a "non LT1"scanmaster on my LT1
  189. new -- TuneMaster
  190. Anyone Know if a Snap-On OBD-I connector will work with Cable???
  191. Anyone with tuning experience in the Tri Cities MI area?
  192. Need OBD1 Diagnostic software
  193. Bad PCM?
  194. LT1 edit price?
  195. LS1 Edit vs. Auto tap
  196. Tunercat: Low octane tables
  197. Read .LT1 pcm file
  198. %change to fuel/air ratio @ WOT
  199. Tunercat & M6 idle tables
  200. Need stock values in LT4 Main Spark Table
  201. wHAT PROGRAM ARE OUT THERE FOR 97'S
  202. Should I add fuel to my tuning and take 1* of timing back out?
  203. Anybody know if my injectors are maxed out?
  204. computer diagnostics with labtop
  205. What are you running for IAC counts at idle?
  206. Help with fuel tuning
  207. Holy transmission tables/Tunercat
  208. Hmm...how did you tune for gas mileage?
  209. Open Vs Close Loop
  210. '02 z28 programming
  211. How to tune w/ wideband o2?
  212. Random multiple DTCs?
  213. tuning help, what do i do?
  214. Transmission tables
  215. PCM Reprogramming???
  216. anybody familiar with the ROMutator?
  217. Should i switch to OBD1? What will it do for me?
  218. PCM Adjusting To New Mods ?
  219. Stock Engine w/ some tuning
  220. file for 224 236 cam and ported heads
  221. Thanks to Javan at B & B Electronics!
  222. Andrew @ AKMCAbles where is he??
  223. Tranny shift point question
  224. Where can I find the .lt1 to .bin (lt1edit to tunercat) converter?
  225. Dependable parts, reasonable prices
  226. Datalogging
  227. Installed bigger cam,Can I start it up on stock program?
  228. Looking for tuner cat pro
  229. tuner cat (spec..)
  230. WOT tuning's effect on part throttle performance
  231. Transmission Shift Table??
  232. What tuning softwares are out there???
  233. 94 Z blowing the 15amp courtesy fuse
  234. plz take a look at my tune and help
  235. What do i need?
  236. "Transmission Perform" input pin on PCM?
  237. Correcting the VSS from a M6 to 700r4 swap with LT1 Edit
  238. BLM short-term corrections in PE mode???
  239. Knock retard
  240. 93 Lt1 Pcm
  241. Had car dynotuned and now A/C is affecting tach readings
  242. I think PCM problems...
  243. Fuel Injection not getting Ground Pulse from PCM ... Need Help ASAP
  244. Where to buy LT1 Edit
  245. Tuner won't work on my car anymore..
  246. Why so much Timing
  247. TPIS chip users?
  248. Ac request signal NON STOCK USES
  249. Tryin speed density
  250. CAGS trick to disable the dreaded 3-2 shift
