PDA
View Full Version : Computer Diagnostics and Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 [36]
  1. A4 manual shift 2 - 3 hits limiter
  2. So many Fuel Injection Setups.!!!!! Help Me choose
  3. Jet Stage 2 chip???
  4. PC to ALDL question, ie. programming with a homeade PC-ALDL cable
  5. Mr Mattei- You still around?
  6. Consequences of Exhaust leaks..
  7. HOW DO I KEEP MY 4L60 TRANNY'S TORQUE CONVERTER FROM LOCKING UP IN 3RD GEAR AT WOT?
  8. Locked hypertech, need help!
  9. tuning?
  10. Any one have the Windows based flash program for Tunercat??
  11. Trans pressure tables in Tunercat
  12. something gone wrong after warm up
  13. went over pothole,,now no power windows and radio???
  14. diagnostic equipment
  15. PCM interchangability!!!!!!!!! VERY COOL
  16. lt1 edit
  17. B.S. Gains
  18. Need help w/ laptop and tunercat
  19. Mr. Mattei, I need help on my programming-new 24lb svo's
  20. could the TPS really make a difference???
  21. DIE REV LIMITER DIE!!!!!!!!!!!!!!!
  22. Checksum ? from Lt-1 Edit
  23. need info on program change after rear gear change on A4 car
  24. Hitting Rev Limiter on 1-2 Shift...
  25. How do you..........
  26. DTC 26 quad driver module
  27. Where can I find pinouts?
  28. Modified A4 users, need tranny help
  29. LT1 Edit for '94?
  30. Need help troubleshooting '97 SS
  31. 02 sensor and/or O2 simulator?
  32. Opening freescan files..?
  33. what programmer should I buy to do the following?
  34. jet chips,hypertech power mojule....which is best
  35. DIY ALDL Cable?? (search)
  36. Help! SES Light but no code!
  37. Anyone want to take a look at my OBDII LT1 Edit file?
  38. What is my shift RPM?
  39. idle problem after warmup, and...
  40. lt1 edit.....shft firmness
  41. Alright, I have the Stock Flash of my puter, what next???
  42. Where to get windows version of tunercat??
  43. Changes to Injector Offset in LT 1 Edit
  44. want to learn to program
  45. Tunercat Flash read/ Exe
  46. What is the difference between the Hypertech HPP+ & HPP3
  47. Where to buy Siemens 40amp waterproof relays?
  48. Speedo Recalibration
  49. Dynotuning
  50. Injuner or some with good tunning skills need help
  51. LT1 Edit ???
  52. Gains from pcmforless with just bolt ons?
  53. any one have a stock 95 auto bin or lt1 file
  54. Left O2 Sensor stuck at 1097mv, even after replacing it
  55. No cyl. volume or fuel inj. flow rate in Fastchip program
  56. Why does my car purge the ccp so much
  57. How to recalibrate MAF to read to 512 from 471 with Tunercat?
  58. I know nothing about scanning. Help me out.
  59. ( SES ) P0174 Fuel Trim System Lean Bank 2
  60. VE Master for 93's?
  61. Internally modify OBDI computer for an OBDII car?
  62. Any programs work w/ MAC?
  63. airfoil experience....and IAC counts.
  64. Problems with ECU
  65. Service engine light is driving me crazy!
  66. Tunercat connection issues
  67. Blower .bin files.
  68. Best place to purchase a PCM???
  69. Tuning For Heat/Humidity
  70. TC error code 75?????
  71. SES problem (I know you see these often...sorry)
  72. major problem with HPP
  73. Auto X ray
  74. Anyone else have issues with AutoTap Windows Software v2.01
  75. Anyone gone from Stock pcm tuning to the F.A.S.T system
  76. Whats my timing??
  77. SPLIT BLM'S...SOLVED.
  78. PCM Diagram.
  79. 36* in program....datamaster says 39*
  80. Fastchip or PCMforless
  81. Who makes the best diagnostic/data log program for OBD1 ?
  82. Strange Idle after PCM Tune? IAC Related?
  83. Comp Cams 230/236 and Emissions ?
  84. Cylinder Volume with Tunercat...
  85. DIY Wideband logging
  86. DFI TUNING SHOPS IN NEW JERSEY?
