- individual cylinder fuel trim tables
- 96 LT1 will not start on hot days.
- My Z wont start if I drive it on hot days.
- how will car run with no coolant temp sensor?
- Brents page of lt1edit files?
- Split BLM fix
- Finally fixed the high stall problem!!
- code 44 (I think)
- 350 Computer Crap
- lt1 editing software?
- Street wideband - FJO Racing
- Hypertech for a 99 V6?
- uploading with LT1 edit and then swaping chips?
- 2nd computer for emissions?
- Editor and Lightweight battery
- DFCO (Decel. Fuel Cut Off) Question
- definition files
- 396 lt-1 tuners please read
- tunercat( geting xtra timing from somewhere?)
- tunercat(% change to fuel air ratio v.s rpm @wot)
- Question about adjusting timing...
- Obd1 Chips
- Timing using LS1 edit
- SES lights and tunning
- aftermarket computer recommendations
- knock retard--hard starting?
- Removing timing at start up
- 1/4 mile test data on a new 396
- Were do I start?
- AFR vs temp weird question
- How to "re-play" a log in Autotap??
- SES light/Short Shift
- Firming up shifts
- Getting there, just need some assistance...IAC and Idle low
- question about obd2 pcm and RPMs
- A home computer problem...
- heads/hotcam program
- Looking to buy tuner cat ?
- possibly bad ground computer problems
- A computer ? about engine swaping
- good article on spark timing inside....
- tuning for the track tomorrow....need help
- how do i turn off cags/ trouble codes on lt1 edit??
- HELP......PCM not responding
- FAST Q? Lean spike on tip in?
- Datamaster scan
- Going to dyno ???
- Reading plugs to tune WOT
- What do you change when dynoing an A4
- 78 RF Solenoid Open or Short to Battery???What does it mean??
- Who to send my computer too
- I want high timing file
- Dont know if one exists, but..
- Datamaster says I have no PCM!
- Need help!(OBD2 to OBD1 swap)
- tuning 2001 GMC truck
- will this adapter work?
- How to correct BLM's
- dyno 2000 files
- Need stock OBDI A4 pcm file for LT1 edit...
- scanmaster won't start
- How to Disable PE mode?
- Fuel map,Timing table.....
- We need a "how to tune walkthrough"
- Got pcm program need help
- SD LT1 tuners - PE vs RPM
- Question about cables for LT1 Edit.
- tuner cat( individual fuel trim)
- GMS MAF & tunercat
- T56 to TH400 swap...
- what changes(tunercat)
- ABS Codes
- How do you know if freescan info is good
- 3rd gen ECM probs....
- Just used free OBDI scanner, some notes, help me make sense of it!!
- can't get Belkin F5U103 to work
- LT1Edit and new dell laptop not working!!
- 93 chips? What kinda eprom do i buy?
- playing with tuner cat what does shift time mean
- Autotap users, please help
- WOT Tuning Without a Wideband - A Discussion
- How to tune for timing on the streets?
- Question about LS1 edit
- Best OBDII scan tool...
- No one can give me a diagnostic! anyone ever have this promblem?
- Anyone ever add (+) fuel in PE mode?
- sevice codes??
- LT4 HotCam File
- LT1 Edit Starting Point
- Custom chip for charger??
- ? About Mr.Dyno.com equipment
- Who uses OBDII on their modified LT1?
- Tuning Problems
- Questions about Tunercat
- PUtting 96 trans in 94 car; PCM conflicts?
- i need a program for sunday !!!!!!!!
- Cheaper alternative to AKM cable?
- 26 and 46 error codes
- Alpha N
- If madwolf does my proggy, what all do I need to datalog and poss slight tune
- Cylinder volume for my 355 ?
- Disable EGR in LT1 Edit
- BLM's need some help see inside?
- What Cylinder Size do I use in LT-1 Edit
- PCM Programing
- what is your WOT timing?
- new to programming send me your tuner cat files please
- Can someone email me a stock A4 text file from Tunercat.
- Wideband O2
- LT1 computer control of third-gen style dist
- startup problems
- ses light and code downlaod
- Sorry tried both Tuning and LT1 Tech. Need tuner cat help.
- Is this possible?
- a4 and tuner cat
- PE tuning
- SES light again
- 140 IAC Count from Scanmaster??
- new to tunercat
- What table in tunercat to lower shift rpms?
- Which code reader?
- can guys running LT1-Edit use bin files from someone w/tunercat and vise versa
- Need help with low RPM bucking and surging..
- getting into tuning?
- Trouble w/DataMaster (trial expired but i have even recorded a run)
- can someone explain what wideband 02 dyno is
- A4 Tuner Cat shift table question?
- Wrecked My 98... Cant Reprogram My Hypertech
- Laptop Mount
- cant fix my 1800-2000 RPM knock retard!
- someone please help me with this airbag light
- Using AutoXray with gutted car
- Oxygen Sensor Readings
- ever fry a PCM and get it replaced under warrenty
- Accuracy on DIY wideband from techedge Australia
- Spark advance!!!
- Transmission line pressures
- how do i change idle rpm with tunercat?
- Hooking a 93z to a laptop??? New chips?
- I want to use Granatelli LS1 MAF, need help!!!
- egr and timing advance ???s
- Cell 18 for anything off idle?
- AutoTap Users: C'mon In
- Can a piggyback chip be installed backwards???
- anyone used the RT tuner with the Xtronics ROMulator ?
- why cant i read using tunercat ? used to read just fine
- A4 tranny bounces off rev limiter before shift after programming?
- How does PCM read speed?
- tuning advice
- KR when shifting
- Speaking of data loggers...
- Looking for a FAST file for a 396
- Where is extra advance coming from?
- Spark advance, please help.
- Getting a few codes, please help?
- I have windows 95, do I need to upgrade
- odd OBDII code problem
- How to make my A4 shift like it has a shift kit?
- Autotap 02mv Question??
- Wideband dynoing - new bung required?
- MAF table Hz - what are they?
- Who wants to evaluate my freescan logs.
- Code P1107?
- low coolant temp code keeps coming up
- Spark advance under boost question?
- Newbie can't get Freescan to work, help?
- May have found a solution to KR...please check out!
- Where to put scanmaster on TA?
- How do I make a '94 LT1 OBD2?
- Does a Bad Injector Driver Mean a Bad PCM?
- PCM for less tune ??
- F.A.S.T. tuning question
- Heads/ Cam Upgrade
- Easy ? About VE Tables and MAF Tables..
- tunercat injector help needed
- keep frying pcms with tunnercat uploader
- LS1 Tuning
- Conversion ODBII to ODBI Speed Density
- Low Trac Light On And Abs Keeps Comming On?
- Can someone clairify
- Anyone have FAST file?
- question about ses codes
- how to comp. scan 5.7 ltr vortec tahoe?
- Makin the A4 shift
- PCM "loses it memory"
- Tuner Cat 1.98
- Checking SES light without HPP or laptop
- lean bank 2 LS1
- what's the deal? no tunercat for obdII?!
- '95 Dodge diesel computer reprogram
- PCM Programming Prob
- Could a bad O2 cause....
- OBD2 to 1 conversion.
- Simply question about turnercat
- How much wot timing can this car run?
- B&M 3000 & Tuner Cat???
- MSD Start/Retard Box, affecting timing?
- With tunercat or LT1 edit can u tell the PC that it has 28 lbs/hr FI's?
- problem with A31p IBM laptop and AKM cable
- Cable question
- timing question
- What power adder is easiest to tune for?? N2O vs Blower??
- Will a '94 computer bolt up to a '93?
- Engine VE
- Still having trouble
- anyone have O2 sensor voltage/ fuel ratio chart
- mass air for speed density??
- knock retard at just 10-12% throttle???
- 42# SVO "Lightening" injector help?
- URGENT car wont run
- Price for a tunercat tune?
- ported MAF sensor
- tuning stuff
- 93 Stock Chips Question
- DTC 55 Fuel Lean Monitor
- TunerCat injector offsets for 93's
- new to this
- Anyone running FAST and an Ignittion Box?
- Increased fuel = increased idle?
- If I bought LT1 edit, could some of you experts on here help me out.
- A4 Transmission Settings
- 0bd1 or 2
- LT1 Files...Can I look at your A4 file?
- Getting ready to fire the car up but have ? on tuning??
- OBD-2 program help plz
- PCM for OBDI conversion. A4 or M6 matter?
- DIY o2 sims
- LT1Edit for free?
- tuning masters.. i need your assistance with timing!
- speed density vs maf for FI?
- newbie ? how do you burn your own chips?
- Checksum Disabled???
- My long term fuel trims are...
- Which ALDL cable to get, AKM or Andy's?
- 1996 3.8 Starting Problem
- Knock count
- does a reman. LT1 pcm need to be reflashed?
- Anyone know where i can get GM Weatherpack Crimping tool for a good price?
- Calibration File anyone??
- New to LT1 Edit
- Need some Autotap troubleshooting advise please.
- Please help with computer problem.
- Need help with datamaster file...Look inside
- Ses Light Doesnt Work After Programming
- Offsets for 42lb Lucas/Delphi injectors
- Can I add more timing?
- How is Map related to closed TPS timing?
- obd2 trouble codes
- what are the requirements......
- Disabling the knock sensor and dialing in timing?
