What do I need to get started tuning the car myself?
Old Dec 10, 2002 | 01:43 PM
snksknr94's Avatar
Okay this is going to sound like a dumb newbie question, which I guess it is. None of the local dyno shops do LT1 tuning, only LS1. I want to get a laptop and LT1edit so I can start learning how to tune the car myself. What would be a good laptop that is not extremely expensive, because this would be my only use for it right now? Also, I know I need a harness to connect the laptop to the car, but is there anything else? How does the LT1edit program work and is there a better program out there? I just basically need to know what I need to start tuning the car myself, as I have no experience with this nor do I have any of the needed parts. Thanks!!
Old Dec 10, 2002 | 09:08 PM
drop top steve's Avatar
Go here
http://carputing.com/
Info on LT1 edit, akm cables. I would look at TunerCat also, it's less money. Read the LT1edit list.
Old Dec 10, 2002 | 10:30 PM
DOOM Master's Avatar
Well, since your name is snksknr94, I'm going to assume you have a 94 Z or Firebird/TA, so I'd say you don't need to waste the money on LT1Edit. Go to www.tunercat.com and get that, it's much cheaper, about $100 for all the software. For the cable, go to www.akmcables.com, it'll cost about $100 too. As for a laptop, an old Pentium will work fine. I have a Pentium 120 Mhz and it works great for logging, editting, and programming. Don't need much to run these programs. Try Ebay for a laptop, they usually have some old ones like mine for about $100-$200 that would work just fine.
Old Dec 11, 2002 | 12:05 AM
snksknr94's Avatar
Cool, thanks fellas I'll check out tunercat. Yeah, I just need the laptop to run the program, don't need it for work or anything like that. Thanks again!
Old Dec 13, 2002 | 10:52 AM
BLOWN25TH's Avatar
I would like to know how to start burning my own chips for my also. Can anyone give some details on where and what to buy as far as equipment goes. It's for a 92 TPI computer.
Old Dec 13, 2002 | 02:33 PM
You'd need tunercat and the definition file for the 92 TPI (not sure what is it, but it's listed at tunercat's website). You'd also need an EPROM programmer/reader and a UV eraser to erase the EPROM before you program it. Go here, http://www.thirdgen.org/newdesign/tech/promintro.shtml they have a ton of info on third gen programming that should help you out.
Noenav
Mar 1, 2019 07:38 AM
jayblev95
Jan 20, 2015 01:30 PM
97SSdude
Dec 31, 2014 07:43 PM
thenewkid
Nov 27, 2014 09:41 AM
USAirman93
Nov 24, 2014 03:37 PM
