Can LT1 Edit Program Out A Traction Control Code?
Old Dec 5, 2002 | 06:29 PM
97 6SPEED Z's Avatar
Question Can LT1 Edit Program Out A Traction Control Code?
Okay, here's the question. If I use a non Traction Control rear axle assembly, (i.e. w/o a speed sensor ring in the differential), in a car designed for Traction Control, will it set a PCM or BCM error code??? And, if it will set a code, can it be programmed out of a OBDI PCM with LT1 Edit???
TIA for all replys
Old Dec 12, 2002 | 12:19 PM
MichiganSkip's Avatar
Looks to me like you can disable the traction control on an OBD1 w/LT1_edit
Skip
Jlo
Feb 3, 2015 09:41 PM
squarehead
Jan 15, 2015 07:02 PM
ddr698
Jan 9, 2015 10:05 AM
Jul 4, 2005 05:00 PM
Bando
Aug 2, 2002 02:18 PM
