Wiring up new 4L60E connector
Old Dec 25, 2002 | 02:03 AM
Ryan's Rod's Avatar
I'm doing an install of a 94 LT1 with a stock 94 harness but my trans and computer are both 95. My transmission wasn't locking up in first and I was told that I needed to have PWM solenoid control. I bought a prefabbed connector to wire up with the exta PWM wire. I was also told that all I needed to do was splice it in with the TCC solenoid wire from the PCM but is that true? Will that work? It's going to be a lot harder for me to find the correct pin on the PCM considering my wiring diagrams are for a 94. Thanks
Old Dec 28, 2002 | 12:25 PM
oemfisystems's Avatar
Send me your fax number, and what you need, give me a day or two, and I'll fax you the 95 auto diagram.
jim
Old Dec 28, 2002 | 01:19 PM
OneFlyn95z28's Avatar
the easiest way is to block the PWM valve in the valve body.
No wiring needed
ad356
Apr 22, 2015 08:35 PM
detroit1994z28
Apr 19, 2015 08:11 PM
thenewkid
Apr 12, 2015 07:42 PM
Noer
Feb 28, 2015 11:29 AM
Jan 5, 2015 07:14 PM
