PDA
View Full Version : Computer Diagnostics and Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
  1. Thanks to madz
  2. Idle Tunning (DID SEARCH)
  3. LT1 edit not connecting to car pcm
  4. Weird RPM Sticking at 2,500 some times
  5. True Duals, now I need help w/ tuning
  6. Tried search and nothing, tried resurrected post and nothing....
  7. 96-97 LT1 Tunercat Timing Advance
  8. madz28
  9. keyless entry problem
  10. air temp sensor vs timing?
  11. obd 1 cable
  12. Does datamaster read "speed" wrong?
  13. engine manage
  14. Open the Door...Trunk Pops!!
  15. PCM tuning
  16. New Scanner: Autoxray EZ-Read 2000, "Vehicle not reponding"
  17. otc scanpro 3409
  18. intake backfires
  19. tuning automatics for bigger throttle body
  20. 6 speed conversion cags, and reverse lockout
  21. 383ci cc306 1.6rr's---- looking for a tune..
  22. Worth It?
  23. Gauge for pillar...
  24. Sequential firing???
  25. reprogram needed
  26. Pcm Removal ??
  27. data logs
  28. programmer 94 z and 95 tahoe
  29. V8 Camaro Gauges to install on V6 Camaro
  30. obd1,comp controlled carb ecm help
  31. Found some programming hardware sites
  32. Anyone have an old version of Autotap?
  33. wanting software
  34. Big Stuff 3 with LT1 and SEFI
  35. Possible Failed PCM
  36. 1996 PCM question
  37. t 56 swap
  38. can anyone help me with an TC ECM def file
  39. Changing maf settings affect PE tables?
  40. P1371
  41. dtc 16 & 51. HELP!
  42. Can I make a Man.Fan. Switch with this switch?
  43. tuning for 42# lucas injectors
  44. ....just erased my pcm and then the .... cable failed
  45. LT1 or LS1 drivetrain into truck - computer?
  46. Is this true
  47. Coolant level low??
  48. Missing problem in the LS1!!!
  49. just wondering how hard it is......
  50. MSD Digital 6 Plus
  51. Quick question need some help guys!!
  52. reprogram speedometer for gear change?
  53. How good is your Tune (Poll)
  54. Shift point problems
  55. loads of codes obd1
  56. tunercat tunes for lt1
  57. PCM Tables
  58. MSD Digital 6 Plus
  59. oil reset
  60. Where to buy LT1 Edit?---
  61. In Car Laptop Stands
  62. Service Engine Light after spark plug and wire change
  63. MAF Location = Problems?
  64. where to tune?
  65. Hypertech issues
  66. TunerPro to change speedo?
  67. Transfer frequency from one keyless remote to the other?
  68. pro chips
  69. how to disable vats and egr using cats tuner
  70. Will a manual fan switch eliminate the pcm from turning them on
  71. Question about using an OBDI M6 PCM on an OBDII A4?
  72. any scan tools
  73. LE head cam tuning question
  74. VeMaster Problems
  75. tunning
  76. Integrating an LM-1 into the OBD1 datastream
  77. Using PCM traction control to retard timing.
  78. MSD box braking up logging?
  79. Deleting Vats
  80. How to deactivate my 97 camaros anti-theft
  81. mail oder tune?
  82. PLX M300 or AEM?
  83. AIR pump system on my '99 Z28
  84. car stalls on launch
  85. MadZ28!!!
  86. Security Light Stays on
  87. Injector constant for a 60# Siemens injector please...
  88. getting knock, don't know why
  89. any tips on finding an electrical problem?
  90. wont idle for 20 min
  91. Freescan for '95 Z28
  92. Fried ECM?
  93. Madz28 Tuning
  94. Just Ran an OBD2 Scan
  95. VE table Help
  96. Found A Usb To Serial That Works!
  97. Data Logging for an LS1?
  98. Laptop Connection Problems
  99. Im about to give this car away
  100. Help!!! asap
  101. OBD II SCAN for OBD I
  102. Wideband placement
  103. how to e-mail auto tap logs
  104. Obdii P0100..
  105. what type of laptop do yo use
  106. question about tunercats
  107. cable question
  108. Tunercat for a 96?
  109. Wiring gurus: tan wire abs & ?tcc?
  110. OBD1 Palm Data Logger?
  111. hydraulic roller lifters
  112. #$&*@! SES light on. Poor man's way to check?
  113. ? about fuel pressure vs mixture on speed density
  114. Hey Im looking for BILL from WAUPUN WISCONSIN
  115. Winflash will not connect
  116. speed density mode?
  117. wireing diagram for 94 bose cd player
  118. Software
  119. Bryan at pcm forless
  120. tuning forum for aftermarket EMU's?
  121. 92 Corvette LT1 intermitent miss
  122. data master problem
  123. Will the stock '95 ECM go into PE when engine is cold?
  124. WOT Electronics question
  125. Will higher fuel pressure lower NOx on speed density?
  126. low load bucking
  127. LT1 edit/Tunercats
  128. Diagnostic Scanner
  129. Little help?
  130. High stall obd1 fix people
  131. Madz28?? No response?
  132. cable help please
  133. pcm forless???????
  134. Help with Fastchip Options/Setup 3.4
  135. PE Idle Help!!!
  136. Any EFI Live users in ARKANSAS.
  137. Help for adjusting timing w/TunerCat
  138. Question for PCM For Less
  139. Need Help with 02 / Fuel Inj Pulse problem
  140. Which Computer?
  141. power programmer plus or 3
  142. whats the difference between the ob1 and ob2?
  143. Help With Pcm
  144. Diagnostic cable for 94Z
  145. ALDL not communicating with Auto X-Ray.
  146. fuel gauge!
  147. not shifting from 2 to 3-HELP!!!
  148. Setting up with Hpertech tuner
  149. Replaced Exhaust now Service Engine light on, Connection?
  150. can't read pcm
  151. Help Please Bank 1 STerm High, only?
  152. christian millards site
  153. Tuners in Savannah
  154. pcm chips
  155. TunerCAT file password?
  156. Tunning for crusing with tunnercats
  157. ? about Freescan start temp
  158. 94 L32 PCM Reading
  159. best chip/programmer
  160. Need help with ALDL Cable!
  161. After Market ECU's
  162. 96 w/ OBD1 comm data + "learn disabled ' before and after O2 replacement
  163. Should my IAC's go above 130 when driving
  164. Computer Controlling Only Fuel
  165. What scanner to use.
  166. Can someone look at my BIN File for me??
  167. OBD2 cable
  168. HELP! 94 Z keyless entry won't work
  169. ODB-II cable questions
  170. anyone know where i can get an OBD1 scanned???
  171. vss, 95 lt1 TH400
  172. Who here has had light throttle cam surge and beaten it? How?
  173. DFCO Problems
  174. Wideband O2 opinions
  175. where can i get a in car mount for my labtop??
  176. Laptop Question
  177. who the best for pcm tune
  178. tuning questions, tuner cat - newbie
  179. IAC at 160 and running very rich
  180. 2nd ECU fired!!!! Whats going on??
  181. Use for OBD2 cables
  182. What to get to program an LT1?
  183. Autozone can't scan my 95?
  184. Help me tune my car
  185. spark retard and CCM questions
  186. How to lower my idle? with tuner cats?
  187. z06 maf tune
  188. A/F ratio ?
  189. Dtc 26 Evap???
  190. free tuning software
  191. transmission dtc code 73????
  192. Headlight problem...
  193. Computer problem, kind of technical.
  194. WTF, datamaster TTS program wont record properly?
  195. Bank 1 Lean only at idle??
  196. LT1 pcm MAF table file values NEEDED
  197. $EE definition file
  198. Lt1 tuning
  199. OBD1 or OBD2 for mild mods & emissions (i've done searches!)
  200. Who has the best price on PCM tunes?
  201. 16188051 "94-95" LT1 PCM pin out
  202. mem-cal number help
  203. hyper tech?
  204. Rev limiter???
  205. Which cable is the best???
  206. Idle speed ..
  207. Any TTS Datamaster experts?
  208. Computer to OBD1 port cable
  209. wont idle properly after driving 381 lt1...
  210. Accel Gen 6 ECM Question
  211. P1860 TCC PWM solenoid Circiut Electrical
  212. Running rich. Someone look at my log.
  213. Do I need the MAF?
  214. Has anyone done an open loop program on a 93?
  215. Forgot how to tune after returning from Army
  216. Actron CP9145 PID questions
  217. What sensors/inputs tell the PCM to turn the fans on/off?
  218. coolant level sensor
  219. Proper way to perform a data log?
  220. ODB2 to OBD1 conversion: cyl balance q
  221. O2 voltage stays 1092?
  222. Question about lean condition(wideband used) only in 3rd gear (A4)?
  223. Jeff Creech Reccomendations?
  224. where can look on my data master file?
  225. OKAY ... so my car shuts off when I unplug MAF
  226. will a scanmaster used for a 94 obd1 car work on a 96 obd2 car?
  227. BLM locker program?
  228. VE tuning
  229. No more knock
  230. ALdl connection problems...Please help..
  231. What scanning software to use?
  232. How do I learn to tune?
  233. Questions on WOT/PE mode, Open/Closed Loop
  234. Make your own ALDL cables
  235. will 100 LL airplane gas kill my o2 sensors
  236. Auto PCM Question
  237. can i do this?
  238. OBDII Software for Elmscan Interface
  239. Tranny shift / possible tune problem
  240. desktop dyno
  241. Using LT1 Edit, how do you turn off the knock sensor?
  242. Bad (corrupt) tune?
  243. Need help creating Timing Table for 396
  244. Tuning for super Heavy shootout in Atl
  245. lt1 edit question
  246. How does my PCM control A/F at WOT?
  247. i have high injector DC, can this be tuned out?
  248. spark advance & another ?
  249. MAF Problem
  250. Why run a standalone ECM?
