PDA
View Full Version : Computer Diagnostics and Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
  1. EE PCM Hack
  2. First Scan TTS Datamaster, Please Tell me if my Numbers are what they should be...
  3. VE tables alter non-SD mode?
  4. What do you need the stock computer for?
  5. TunerCat... How do I change inject.....
  6. knock retard
  7. diablo sport rpm programer
  8. Got PCM4LESS tune in today!
  9. Gen 7 help
  10. Porgramming my v6 computer for 3.73 gears HELP
  11. Help with Jet Tuning software
  12. lt1 edit help supercharged
  13. scanner results
  14. Where to get tuning software?
  15. TPP problem
  16. Opti Dead?
  17. wierd computer problem???
  18. idle with motron 60#s
  19. what gauge?
  20. OBD-1 won't scan
  21. trans out of a 94 into a 95 need bin file?
  22. knock sensor ?
  23. Lean out air/fuel to pass smog?
  24. 84 Camaro Z28 H.O.
  25. code??
  26. Can anyone analyze my Freescan log?
  27. Reprgraming 95 PCM from 120mph to 150mph
  28. abuse mode
  29. RoadRunner PCM
  30. computer question
  31. gen 7 ???
  32. begginer tuner here
  33. Jet Performance chip for 84 Z28
  34. what's a safe redline to tune
  35. Can anyone interpret my latest data log?
  36. When shutting off engine, how do I get the IAC to park not fully opened?
  37. Teach me some basics about LT1EDIT ...
  38. adding timing with 110 octane
  39. O2 Simulator
  40. How Hard To Learn How To Tune???
  41. Need Freescan
  42. turbo 383 LT1/misfire
  43. Freeing up Com ports? TTS
  44. Catalytic converter tuner
  45. actron scanner cp9145 any good ?
  46. Injectors bleeding down
  47. OBD1 forced induction/maxed maf issue
  48. scanner
  49. PCM High Rev Limit
  50. 95 OBD I auto computer into an 94 Z m6?
  51. Question about timing at WOT
  52. Finally got rid of my datalogging demons :D
  53. Lt-1 cop car CPU in Camaro?
  54. knock all over the place, then none
  55. Hypertech fried computer?
  56. edit vin
  57. Why convert an obd2 system to obd1?---
  58. Are all 95's obd1?
  59. "pcm hardware failure (3)" error while tuning pcm
  60. Tranny programming asked differently this time!
  61. can you tune out the after cat O2's?
  62. SLP Programmer
  63. freescan, checksum errors
  64. which tuning software?
  65. Small Correction To Timing Nets Big Gains :)
  66. Car has no power. 15 deg knock. Looking to maybe have it programmed.
  67. OBD not ready
  68. Security Light
  69. tuning my 96 z help
  70. p0300 icm, opti spark? need help
  71. lterm reading high in open loop mode
  72. E85 and OBD1
  73. Help. Autotap file question
  74. Autotap Palm software?
  75. Tuning Software
  76. Should I adjust my stock BLM boundaries?
  77. negative trims after h/c?
  78. Jet DST Software
  79. Theft Detterent Sys????
  80. Hypertech Tuning: Is it hype?
  81. Blowing Ecm/ign Fuse
  82. 94/95 4L60E Parts Swap
  83. Delteq creating DM Data ERR?
  84. cheap tuning software
  85. Tuning a specific cell??? Question please...
  86. ECM identification
  87. Best Laptop tuning/troubleshooting program
  88. tuning the '93 z28
  89. First Datalog, Help Analyzing.
  90. '95 PCM Problems!!!
  91. A few sensor values, from multimeter...
  92. Quick question on OBDII scanners...
  93. Autotap and Ls1edit
  94. 224/230 A4...some tuning tips?
  95. Big Time Newb here needs help....running rich burning too much fuel
  96. Which Tuning Software Should I Use
  97. Timing & Power Question
  98. Need a little advice...trying tuning on my own
  99. ABS / ALDL Stream Reader (Bets Tester Rqd)
  100. 'cooling/TPS' HELP
  101. MAF table adjustment for Ported MAF
  102. getting tunercats and datamaster
  103. Uploading a program with tunercat
  104. help understanding trouble code
  105. Self tuneing software.
  106. Db-9 to Usb interface cable
  107. nooooooooo
  108. Manifold Differential Pressure Sensor
  109. tuning with ls1edit help?
  110. dtc 51 bad checksum
  111. tuning software for 95 obd1 computer
  112. Obd-2 Dtc P1543
  113. 1996 z28 Smog pump removal / ABS light now on ?
  114. Tuner Cat Timing tables
  115. <$10 EEPROM programmer for $EE folks
  116. ported maf
  117. MAF, SD or PE tune please help
  118. which tuner program is vin locked?
  119. iBook
  120. VSS Needed?.
  121. True engine mileage from the computer?
  122. car runs really rich under WOT, new tuner
  123. important question about dash's speedo, laptop and GPS
  124. OBD2 Cables
  125. Quick Props to Bryan @ PCM4LESS......
  126. BLM Low on right, high on left, abnormal?
  127. HELP! 1661 trouble code & emissions failure
  128. Knock sensor problems (maybe)????
  129. OBDI PCM Source?
  130. Got PCcomm......what am I looking at???
  131. mass air flow circuit low?
  132. 91 bird 5.0 with 24#ers
  133. Can I use an M6 obd2 pcm in an A4?
  134. 2 bar MAP sensor
  135. LT1 edit???
  136. no request fro second fanw/ ac
  137. Where can I get an OBD2 ALDL port?
  138. How to get trouble codes from a '95
  139. tunning mass air
  140. obd2 t0 obd1 conversion
  141. who all has...obd2 swap 94
  142. PCM wont communicate with laptop
  143. Turning off the IAC in the PCM
  144. Question
  145. Do LT1's have "Lean Cruise" or a similar option
  146. Tuning software and Cable question
  147. getting dynotuned this weekend, have a question..
  148. Table #'s help please
  149. OBD1 PCM question
  150. Low Octain
  151. boost retard or advance?
  152. TPS Issues
  153. OBD1 conversion ?
  154. Tried to Link to my cars PCM- Getting a "LOCKED" message???
  155. USB datalogging????
  156. Will a "hypertech scanner" read ses codes?
  157. Need to compare a timing table for a larger cammed motor
  158. T-56 swap tuning
  159. downloading 94 program through OBD2 plug?
  160. torque management question
  161. Diff between closed and open loop
  162. A transplanted 93 Z28 Lt1
  163. Sensor circuit commons.. SD vs MAF
  164. Trouble with Freescan
  165. ? ford ecm tunning any body know of programs?
  166. tuner pro
  167. 383 Drowning While Driving ?????
  168. Possible PCM problem?
  169. need some tranny wiring help
  170. NEW TOY: scanner / trip computer
  171. Help tuning open loop and idle...
  172. ECM tuning question
  173. failed program
  174. 95 Impala stock tune.
  175. anybody know a good dynotuner for LT1 in st. louis...
  176. needing new def file.
  177. now that pcm has "learned" it runs like crap
  178. ve table or maf frequency
  179. Datamaster just stopped working
  180. Can ABS be disabled by tuning?
  181. LT1 edit?
  182. 383 tune
  183. New To tuning?
  184. LT1 "commanded afr" pid?
  185. How do I make car run at 14.0AFR closed loop?
  186. Tune LT1 like LS1???
  187. PCM and TPS problem again
  188. running rich 383
  189. Borrow LT1 edit file...
  190. EFILive Scanner with a 96-97 LT1 pcm
  191. PROM ID Question
  192. programing 96 Z28 with laptop
  193. obd2 -> obd1 conversion issues
  194. timing question?
  195. running rich 383
  196. increase timing
  197. %change to fuel/air ratio vs rpm @WOT table
  198. Need a FAST timing tune 355ci turbo lt1
  199. Car throws some codes.
  200. crank sensor code
  201. EGR enable question
  202. computer flash programming ?
  203. how do you adjust timing on
  204. "VATS" I need help with resistance!(shoebox)
  205. random trouble codes for split second
  206. is hypertech chip good upgrade for stock 94 z28
  207. VATS disable?
  208. TTS DataMaster Help
  209. Electrical System going haywire?
  210. Can Someone Help With diagnosising A hard start after 3 days?
  211. freescan???
  212. tunning after cam
  213. Question on differences between manual and auto (stock tune files) for converted car
  214. Can someone take a look at a Datamaster file for me?
  215. HELP ME!! My car idles too high!!
  216. ScanGauge by LinearLogic
  217. Can no signal from VSS cause the car to run bad?
  218. msd digital 6 box - timing retard, knock, & datalogging
  219. 93 camaro chip question
  220. Help!!...superchips #2150 Or Hypertech????
  221. Help !!!!! This Is F*$ken Pissing Me Off !!!!!!!!!!
  222. MXscan for Tunercat OBD II released
  223. Wideband O2 PCM hookup and logging
  224. Dell Pocket PC
  225. Any '94-'95 OBD1 WBO2 users want to test a tool?
  226. Tune myself? Recommendations please
  227. 93 owners
  228. Scanmaster on 93 Camaro?
  229. Code 43.. Please Help...
  230. can't get datamaster to work!!!
  231. Will my cable work with obd II?
  232. somebody analyze this datamaster file
  233. Where to Start
  234. Fyi Mxscan
  235. LT1-edit 2.2 users help needed
  236. Help a noob... Basic Cable Software help?
  237. locking up the converter early??
  238. throttle position problem
  239. Cable for efi live
  240. Can anyone answer ac questions
  241. check engine light...
  242. Can someone help me out with a stock Canadian 95 M6 ecm file?
  243. obd 1 and 2 question
  244. Gen 7 & closed loop corection
  245. Is the AEM widband O2 gauge accurate?
  246. # on back of key fob
  247. Post your tunes (.bin & .lt1 files)
  248. Anyone able to get ahold of Andrew at AKM cables lately?
  249. Changing computer chip
  250. LT1 pcm & DFI Gen 7
