96 hypertech work on a 94?
Old Feb 15, 2003 | 08:41 AM
remaxracer45's Avatar
Will a 96 hypertech power programmer work on a 94 z?
Thanks Shawn
Old Feb 15, 2003 | 01:31 PM
n2oTransAmLT1's Avatar
nope...dont think so. OBD I vs OBD II and I think different connectors. Someone, correct me if Im wrong. If I were you...Ide buy LT1 edit and a laptop. Much more useful than HPP.
Old Feb 15, 2003 | 01:36 PM
c5formetoo's Avatar
i will back you up.it will not work.
Old Feb 15, 2003 | 02:08 PM
fastz28's Avatar
not only is the aldl connector different but odb2 reads more codes and I believe they are different in code, does that make sense?
Old Feb 15, 2003 | 02:29 PM
Dr.Mudge's Avatar
Absolutely different, 94/95 SHOULD work together (other than the fact that the ALDL connector is NOT the same) but as always check with the MFG.
96+ OBD II - whole new ballgame
Old Feb 26, 2003 | 12:47 AM
tom95z28's Avatar
actually the 95 and 95 HPP are 2 seperate part numbers. If you have a 94 HPP it will not work on a 95, and vice versa, don't know why but thats just the way HyperTech did it.
Old Feb 26, 2003 | 01:23 AM
Dr.Mudge's Avatar
The connector on a 94 is OBD I and the 95 connector is OBD II but with an OBD I PCM, so without playing with it, it will not work. However I see no reason ultimately that it should not work, since there are so many used ones out there due to dissatisfied customers though, I'm sure there is no reason to go through such trouble.
thenewkid
Nov 27, 2014 09:41 AM
IgorT.455/406
Jun 4, 2003 03:32 AM
SLIMJIM
Jan 7, 2003 11:06 AM
Chicago94Z28
Aug 28, 2002 08:31 PM
slothgrant
Aug 22, 2002 03:01 PM
