OBD2 W No Crank Pos Sensor???
Hello,
I am Very new to the computer side of engine performance. I am doing heads and cam on my 96 T/A and am considering using the cloyes double roller timing chain. I understand that I will loose the CPS by doing this and need to know if my OBD2 com will still work properly. What would I need to change with LT1 edit and would I be able to moniter for misfires at all?
Thank You,
James Eddy III
Thank You,
James Eddy III
Re: OBD2 W No Crank Pos Sensor???
Originally posted by Quickshotkimber
Hello,
Thank You,
James Eddy III
Hello,
Thank You,
James Eddy III
2 Under "other engine parameters"- "hardware verification".
3 No, you well not beable to see misfires.
stockssn2o
May 25, 2015 08:54 AM
