- Hypertech programmers & shift points....
- Do I need an MSD 6BTM.....
- can someone help me change a tune file?
- 42lb bosch injectors
- which editer to buy?
- having problems with HYPERTECH PP3, need help please
- SES light, then it goes away, no code?
- Why are blower/turbo guys not using...
- anyone know anything about Holley Commander 950 computer
- What is code P131
- Just Boght LT1 Edit and have some questions. Also Knocked .47 with the first time it
- LT1 edit help
- is it true Z28's are downtuned outta the factory???
- Q about MAF.
- What cable fo I need
- nitrous file
- 95 LT1, LTFT 100, running lean, hesitation
- Anybody have a cc503 cam and LT1 edit file
- BLMs at 160. How to fix?
- OBDII
- What can I look for to find out if I'm running rich/lean with Diablosport predator?
- what resistor do i use to make obd 1 pcm work w/ obd 2 k.s?
- Code 23
- Any one ever use Ed Wright Tuning for 50# injectors?
- Matching TTS fields to Freescan...
- Simple A4-M6 swap question
- All you tuning gurus inside please>have ?'s
- Harness Trimming...
- Ryan94ZA4 - OBDI Stall solution question
- 93 to 95 conversion
- Analyze my dyno numbers please ... looooooooong
- Auto X-ray cable question
- cheap laptop for tuning for sale on ebay
- Auto X ray on ebay
- Auto Tap analyzing .....
- Completely disabling EGR and CCP using TUnercat
- Datamaster files inside...what you think?
- TunerCAT and DOS
- Best place to get LT1 Edit???
- Open Loop VS Closed Loop
- OBD1 F-body and B-body differences. HELP!
- will a B-body PCM work in an F-body?
- LT1 Edit open loop program ...a couple qwik questions
- i got a code 2-3 shift solenoid need help!!!
- O2 sim value?
- Ebtcm
- what diagnostic prog. do u guys recommend
- How do you tune out cam surge?
- Fuel Trim 108??
- need FAST info
- WTB FAST DEFI computer?
- Tuning with 50#injectors in the NJ area?
- Question about Tunercat
- any good sites or articles explaining timing
- Lt1 Edit install help
- idle setting
- Is there a difference B/T programmed shift points and actual shift points?
- Cpk Symptoms?
- How to display CSV values properly in MS EXCEL??
- ODB1 and ODB2 cables..
- TunerCat users.... Question inside please....
- "Burst" knock? So there's true knock, false knock...AND "burst" knock? Really?
- correct way to correct knock
- How do these BLM's look....
- obd11 causes misfire with cam?
- Please post your track logs
- possible burnt wire? (not plug wires)
- Motor Magazine's Scanner Tool Review
- 93-obd1
- required parts to finish obd1 conv.
- Tuning reccomendations
- Once the mods are in, how do I go about programming? With LT1 edit?
- Logged 1/4mi runs, KR comes and goes
- Urban Suburban Question
- tazzo vs. g-tech
- FS:OBD1 conversion "kit" & 50# Injectors
- wierdest thing i have ever seen
- What 'log'ing software does everyone use?
- Autotap question in relation to LT1 Edit
- Pro Tune/Self Tune
- Help w/ '93 Eproms
- Editing MAF calibration tables
- LT1 EDIT tuning ?'s/GTP Heads>P6 Cam
- 7000+ rpm on stock PCM?
- Lt1 Edit
- Tunercat - getting to idle, removing fuel
- Tunercat 1993 bins DA3 (CAR STARTS !!! WOOT !!)
- SES light blinked at me a few times.
- Where to buy tunercat?
- WB O2 in place of Stock O2
- Need a CC306 file
- PCMforless... any complaints / regrets?
- Programming my 94 z
- Can someone look at my Datamaster logs?
- Spilt BLM's, going high on 1 side
- obd2 to obd1
- After swapping to an OBDI conversion computer....
- Piggyback Fuel Computer.. check this out has anyone tried to make this work
- Cable for TunerCat and 94-95 LT1's
- Scanners for Laptops???...
- ECM Page Update.....its ready to try
- changing computer from obd1-obd2. Need advice please
- Emissions tuning
- Need PROM burned for 93 T/A
- Can someone troubleshoot these codes: 16,42,44,52.
- PCM fried??
- Speed Scene Wiring
- passed IM240 emissions with heads/cam/LT's
- Spark retard with no knock count increase?
- Please help.
- Power Programmer ?????'s
- Does the PCM store run history?
- ?? about Datamaster
- bad hesitation at 5200rpm
- manual fan switch problem, please help
- Duty cycle 103.5% ?? Help
- tranny not shifting
- I keep on blowin my fuse--HELP!
- DFI or lt1 edit
- LT1 Edit VS Tunercat.. Which is better
- What does this code mean??
- trouble after car warms up
- Bad MAF?
- custom progarm (vs) HPPP III
- tuning a turbo lt1 by yourself
- HPP3 cable: will it work with lt1 edit?
- Where can I download a free data logging program
- How to adjust rpm on cold start?
- Is it worth it to learn how to program my own PCM?
- best place to buy Accel Gen7 DFI
- Anyone with an A4 and 52mm TB?
- argh! spark retard and knock counts? (long)
- Help on Open loop A/F Ratio Clairification!!
- How can I control a 96 4L60E with a 95PCM?
- Need wiring help
- can I beg or plead with someone to look at my file
- Anyone Ever Change Your RPM BLM Boundaries...Significantly?
- Timing Question
- How to add fuel with LT1 Edit?
- WOT tuning
- VEMaster for 93's
- Do i have to have a hypertech PP for gear ratio changes
- LT1 edit question
- Does anyone offer free scan tool for odb2?
- XE224/230, 30# inject, what settings with tunercat?
- Computer stays in cells 16, 17, & 18..why?
- help service engine soon light on and nothings wrong with the engine
- ve master
- What exactly is torque management?
- Odd injector lbs/hr noticed, anyone else notice this?
- Timing Question
- How to add Timing in LT1-Edit
- Please?? Pretty please?
- 50lb Injectors
- How to read a different PCM than LT1 (chevy truck PCMs)
- Need trans expert to look at this set of tables.
- Logging with Lambdaboy or Tech-edge
- Bolt ons: What to do first w/ tunercat?
- Spark retard going from part-throttle to WOT
- 02 SIms!?
- 93 bin dump
- DIY Wideband O2... anyone build one yet?
- 02 mV ?
- Help with WOT fuel mixture
- After Modifying My VE Tables, I Still Run Rich!!!!
- Part number for a 95 PCM
- $8.95 for a chip
- New mods, CC306/GTP-II heads...fuel probs? Logs w/i
- Programming firmer shifts?
- Help!I cant get on to pcmforless.com!!
- speedo calibration
- Hitting rev limitier at 6375 but setting is at 6600???
- NEED HELP keep hitting rev limiter on 2-3 shift!
- Yet some more why do I have knock retard questions.
- lean spike
- Can someone please look at my logged run...
- Lt1 Edit instructions
- Operation of T56 reverse lockout solenoid
- OPEN LOOP ONLY question
- Schematics for the 8051 PCM
- tuner cat ----tuning a few functions
- How to retard timing and richen fuel
- Pcmforless Kicks Ass!!!!!
- best programer for OBDII?
- Auto program on M6 (LS1)
- Moding aftermarket TB to get equal left/right BLMs
- Passing Emissions suggestions
- Circuit to activate at O2 700mv or less??
- Best Datalogging for air/fuel on ODBI
- Custom Tuning
- OBD1 guide
- help............
- 93 pcm to later style
- Z06 MAF table
- BLM's high at idle
- Emissions testing
- Functions of #10 fuse in underhood block???
- How can I "tune away" carbon on spark plugs with LT1_Edit?
- VE Calculator
- Paging ELIS...
- Anyone Make an Affordable tuning Package for my OBD II??
- 30lb injectors, tunercat
- FreeScan: ? about 02 volts
- Does PCM tuning offer any performance advantages for Stock 94 w/ Bolt ons
- FAST Group buy
- Looking for a file XE 230/236 or XE236/242
- Formula for A/F ratio??
- What steps do you guys use to tune lower RPM stuff to make the car more driveable
- trouble reading copying pcm
- 93 Tuning Questions!
- tell me your speedo settings
- CAGS questions
- LT1 help please
- What software is made to tune 93s
- OBD2 to OBD1
- LT1 edit and Hypertech can they be used together?
- Base tuning with F.A.S.T for first startup of 396. Questions within please.
- Air Fuel Ratio in Free Scan???
- Can I Regulate the Cooling Fan Operation with LT1Edit???
- BLM's Off - Am I on the right track?
- TPS voltage
- TC Won't lock
- Any difference in lt-1 edit and tunercat?
- How too see my injector duty cycles????
- i ma buying a replacement pcm, will a buick roadmaster pcm work?
- Tuning questions: how to make my car behave like I want it
- New FreeScan logs - got knock?
- What is the CKP sensor
- New Beta of Datamaster Available
- how to do Fan setting other than HPP3?
- (M6) Trouble shifting to reverse, electrical/computer???
- Looking for a email address for Andy Whittaker
- any have a program for a stock car with bolt ons??
- Need LT1 edit program for CC306 with ported LT4 heads.
- logged with datamaster, now what?
- how to program for 26 injectors
- Why does changing the injector constant or the maf tables change so much the AFR????
- using a 96 PCM in a 95?
- Scantool for WindowsCE?
- Tuning Help...
- I think I hit my target, editing shift points
- Instrument Cluster Conversion
- PCM source
- Anyone have a stock 93, M6, M28 .bin file?
- Explain N20 tuning real quick...Im confused.
- I Love Tunercat
- TPS question
- SOS Chip Burning HELP
- Any with OBD2 LT1 edit????
- 120 dollar fuel comp
