Please take a look at these files!
12.11 pass
Poorly Running
Guys with datamaster can you please analyze the data I logged from a couple of completely different passes. As you can see on one run I ran a 12.11 pass at 115. This other pass was a measely 109 mph pass, conditions were about the same. So I have ruled that out as a major factor.
Thanks! Matt
Edited: To make the files CSV's. Sorry
Poorly Running
Thanks! Matt
Yea man, you only exported 1 row of data
You need to go back to DataMaster and enter how many records you want exported... You from 1 to the end... You can see how many there are in the normal screen towards the bottom right hand side.
Jeff
Jeff
You should really output RPM and Road Speed it makes reading your file much easier
One thing i'm noticing tho is ALOT of knock... not really high numbers, but almost constant knock, sometimes even when TPS = 0 (but I can't tell whats going on there as I don't see RPM and road speed)
Jeff
Jeff
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
NewsBot
Sep 30, 2015 04:20 PM
NewsBot
Sep 15, 2015 11:53 AM
NewsBot
Sep 14, 2015 02:02 AM
tommalcolm
Sep 11, 2015 03:39 PM
