- OBD 2 scan tool $84.99
- Please view datalog
- Modified LS1 won't Idle
- anyone have a 1996 Z28 A4 - Stock tune file
- Freescan
- Need an ABS code scanner. Monitor 4000e?
- datalogged my car.....LTFT really high
- How to d'load $EE.zdf on Windows 8?
- scanned car got 8 code but car doesnt have cel
- PCM issues 95 Camaro LT1
- cant datalog
- Scan a 94 with 95 cable
- Datalog inside...Please have a look
- Scan9495: Free OBD1 scan app for 93/94/95 LT1
- Abs-inop, no communication with ebcm
- whats my diagnosis?
- TPS problem
- head scratcher, fans and reverse lock out...
- P0107 & C0240 codes won't clear
- Ideal FreeScan Data Values?
- P0100 Problem with M.A.F.
- LT1 OBD1 Tuning in DC Metro area
- Modified LS1 won't idle
- runtime error 339
- Tuning for a soon to be boosted lt1, have I missed anything?
- Rich Mixture Question
- why wont anyone help
- 92 firebird
- WOT AFR of 8.5 Question
- Dyno Day with Bryan Herter
- 1995 OBD2 style OBD1 -- iphone apps that work with this?
- tunerpro help
- tuning for an 96 lt1 camaro
- 95 lt1 car want to switch to crate motor with standalone efi
- 97 LT1: Min. Cool. Temp. for Closed Loop, Cold MAT
- Datalogging OBD-II LT1
- Real Story getting codes from OBDI
- LT1 Edit Commands
- MAF signal wire only getting 2.7 volts
- Please help me interpret my Datalog
- mod pcm by soldering resistor
- has anyone delt with race proven motorsports in DE
- 95 LT1 OBD1 with 16pin(have tune already) want to start tuning.
- ac controller blowing ecm?
- 1.5 BAR map sensor?
- tuning; timing & VE tables
- Which tuner cable Moates or Tunercat?
- can someone take a look at my datalog
- O2 sensor questions
- OBD2 laptop tuning software?
- on going issues
- New Laptop - Need A Copy Of Freescan
- Data Log
- diagnostics show 138420 rpm at rest
- Tuning programs
- handheld tuner or mail order tune
- Codes 171, 174, and 400, but EGR valve good
- LT1 Stock tune fan threshold temps?
- Using Tunerpro RT to tune out rear o2?6+
- 95 z m6 ob1 to ob2 convert?
- LT1 edit
- VE Master help
- Questions?
- check engine light
- Possible pcm problem?
- 1993 z28 tune-is A4 and M6 tune interchangeable?
- oxygen sensor the cause of stumble and pop?
- Confused on code
- cant read pcm
- pcm tune or b&m kits
- Knock sensor code 43
- knock sensor DTC AI 383 LT1
- Difference Scannmaster and DataMaster
- Trying to get Tunercats to read my car.
- OBD2 Data logging software
- Failed Emissions
- datamaster trouble
- tuning question?
- Wide Open Throttle Tuning Q's
- Best PCM to use with LSx Swap
- Egr ???
- Please look at my datamaster file
- scan tool
- diagnostics cable
- lc 1 logging
- Verify my log
- MPH Readings very low even on freeway
- DTC P0171 after Mail Order Tune...
- Tuned Log Check
- 95 T/A Tunercats - can someone show me where to change my fan settings?
- New to pcm tuning
- permanent pcm damage?
- Chip to retard performance?
- Tunercat/Datamaster question
- 92 Camaro RS. Very high idle
- repinning LT1 harness question
- Help! Low oil light and ses
- Need help....Replace computer or not????
- Good tuning platform?
- Timing and Knock Retard....
- Tuning OBD1 for Third Gen 350 swap
- Relay for CEL
- VATS issues on third gen
- 93 Z28 - Need Help with Data Master .uni File
- Knock Retard??? Help
- Knock Help.
- DTC 34 map sensor low
- 94 Z28 high idle
- Tunercats question
- GM Tech 2 experience?
- Dtc codes
- Lt1 in a '88 944 tune issue
- disconnect alarm system
- Switch from Open to Closed Loop?
- Where does spark advance get data?
- 96 Z running extreamly rich.
- Closed Throttle Spark Advance
- New well breathing TFS heads. Now car runs kinda lean...
- Slow acceleration and running rough under 3000 rpm
- Shift Soleniod Enable/Disable?
- 94 cc306 a4 and or m6 tune info
- Help Top End Power Loss LT1
- Help car dies
- DataMaster -- LTerm Counts read low (108) running rich...
- tune for gas mileage
- Slight miss and sometimes popping
- Code help please
- O2 Threshholds and Long Tube headers?
- obd 1 scaner for linux
- crack thr blades or drill 11/64 hole?
- Stock Engine, Stock Tune, High BLM's? *.uni/*.csv included
- LT1 to LSX conversion: Wiring harness question
- LT1 EGR system - avoid codes by just plugging in solenoid (EGR valve disconnected)?
- Throwing codes from O2 sensor monitoring and catalyst monitoring?
- Maybe An Easy Question Regarding Fuel Injector Size Changes?
- PCM programming to show system monitors as "ready"?
- mail tune
- obd1
- p4030
- p4030
- Anyone else running the AEM 30-4100 with stock ECU?
- MAF Translator plus
- Tuning
- True Duels wideband placement?
- Datamaster help
- OBDII chip programmer advise
- running alittle rich. datamaster logs
- What ECMs to look for - '96 LT1 M6?
- Anyone tune their car with a FAST system?
- vats system bypassing
- Please explain how I am to properly set up my blm boundaries
- Heads/Cam Timing HELP PLZ
- What connector is this??
- obd port problem
- Cant get my laptop to talk to my car ecm
- how do i run diagnostics check on 95 Z28
- Maf, open loop tuning, which tables, 95 OBD1 using tunercat.
- LT1 MAF Readings -- What should I expect?
- OD problem
- Need a 95 Z28 A4 with a 2.73 rear end bin.
- 95 z28 electrical issue. HELP!!!
- P0403,p0443
- Can someone look at my datalog?
- Security light on
- I want to buy a nice OBD2 scanner
- Going for a new tune...
- Where can I find this?
- Check for stored codes - software
- Help me get started
- lt1 tuning
- Mail Order Tune
- CC306 Tuning
- PROM Part # for 305 to 350 TBI Swap
- TTS Datamaster help
- Need some PCM help
- 2001 camaro z28 bcm failed...possible fix?
- DTC 32 after wot
- Jet Chip BDZL-S2
- 95 3.4 hard cold start
- ECM EGR delete for cheap
- Knock counts readings with Datamaster
- Cant figure out tuner cats
- LT1 Pro Tuning Kits reads diagnostic codes ?
- hypertech power programer plus
- Check Gauges Light flashing rapidly
- TECH gurus help me find this cable plz!!!
- What Type of O2 sensors do i have?
- blm locker
- killed my PCM
- tuning for wot
- Is my PCM now failed?
- VSS Troubleshooting -- Odd Voltage at PCM
- Car died! Please HELP!!!
- LT1 Datamaster file, please look for irregularities
- LS1 edit stock 2000 Camaro M6 file
- Intermittent Shut down once vehicle warms up (and horn randomly beeping)
- Data log files help.
- datamaster files, is my clutch slipping?
- 12200411 and 9354896 ecm pins.....
- tuning afr in pe mode with tuner cats
- Miniram, big cam spark table help
- cold start tune
- 96 obdII to obdI
- Tried everything still no speedometer
- No comuniction 94 ecu & harness swap
- Wiring Harness
- LMA-2 Setup on LT1
- twin turbo impalla ss troubleshooting help
- tuning MAF
- 95 Z28 with Vette LT1
- blm issue in data log
- Getting Code 61
- check engine light on and off
- Using generic LT1 Edit tunes with Tuner CATS
- LT1 stuck in cells 16, 17, & 18
- Can somebody help??
- Delteq with LM1 Wideband rpm help
- 95 Z28 LT1 A4 3.73 Bin
- No revs past 2500 datamaster file included
- LT-1 Edit
- hello
- mac?!?
- 96 Fbody PCM work in 96 Vette?
- LT1 cold start idle tuning
- Getting Code 1642
- need help with tune datalog inside
- 94 z28 misfiring HELP
- looking for .bin files to compare data
- code 18 (not in use?)
- got a problem do you think its the pcm or something else
- Force motor vs trans temp vs press
- p1351 code resolved
- $EE 95 f-body definition file needed ASAP
- can u use any lt1 94-95 pcm in 95 trans am ?
- OBDI PCM Issues?
- Interface cable
- Ecm change ou
- SES Light at idle (high map sensor reading)
- LT1 Won't Start Without Starting Fluid
- somebody please help me with injector flow rate scale
- got trouble codes 83 and 84 and 28
- Megasquirt piggyback the LT1 PCM?
- Few tuning questions
- Having trouble with Free Scan, please help!
- need a new ecm
- Switching from M6 codes to A4 codes
- speedometer help
- AC won't run below 2000 RPM exactly
- PCM O2's and Wideband O2 reading opposite at idle
- I need a wire diagram for blower motor and hvac
