PDA
View Full Version : Computer Diagnostics and Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 [32] 33 34 35 36
  1. LT1 edit w/ PCM For Less
  2. Trouble Code Help. Please?
  3. In the power enrichment vs RPM table...
  4. F.A.S.T. who deals real cheap ?
  5. Benefit of alot of timing at a high KPA and low RPM?
  6. where to buy tuner cat or lt1 edit?
  7. LT1 Edit files for CC XE 224/230? Anyone?
  8. ses light still on
  9. Reading DTC's w/ PCMCOMM from Carputing
  10. Injectors, Fuel pump, and Dry kit question inside please...
  11. changing injector
  12. Guys running NOS and tuning themselves, quick question inside please...
  13. flash chip sockets
  14. How do I use freescan properly?
  15. no OBD link in a 93?
  16. What to do first with tunercat?!
  17. Would anyone like to see a tuning column in GMHP??
  18. best software to scan/program LT1s
  19. Injector constant and offsets??
  20. TunerCat timing tables, which way to go...
  21. VEmaster results... Look....
  22. Tuner cat or LT1edit?
  23. Individual Cylinder Fuel trims
  24. Looking for PCM file.
  25. Paging Andrew Mattei
  26. computer edit for m6
  27. LT1 Edit A4/ shiftpoints
  28. Data Master engine DTC error
  29. Helpp!!! I Need Pcm Tuning For 96 Z In Nj A.s.a.p.
  30. When to switch to aftermarket?
  31. Will this cable work with LT1edit/free scan on my 95 Z?
  32. v6-lt1 swap qpu question
  33. Idle MAP Cell 4?
  34. This cannot be good......
  35. Why can't I get AT EFI Live5.0 to work???
  36. More problems with F.A.S.T
  37. HPP3 VIN mismatch...how to get it back to stock...
  38. Making my own OBD 1/2 Cable for 95 Z
  39. Will Predator void my warranty?
  40. How does this timing table look?
  41. How high to adjust line pressure?
  42. Tuning A/F ratio?
  43. Why remove EGR???
  44. 93Z, looking for Data Program, DataMaster or Turbo-Link???
  45. Lt4 Knock module vs. Lt1 Knock Module
  46. pcm wiring
  47. VE tables and increasing displacement
  48. Need PCM options and opinions
  49. Tunercat help
  50. TurboLink Promo
  51. Shift firmess value #
  52. what will tuning do for me??
  53. 95 PCM issues...
  54. High KS Count without any Spark retard
  55. is this too much timing?
  56. When are Predator Updates going to be available online?
  57. LT1 base gen 6 DFI maps needed
  58. 97 PCM in a 95
  59. 94PCM in 93 car
  60. Tune help please
  61. Auto file in M6 car
  62. anyone with OBD2 dyno experience HELP
  63. PDA, LT1, Need Help w/Editing
  64. Need a lt1 edit file for a stock lt1 supercharged car.
  65. Check out my Freescan Track data. Looking for suggestions...
  66. Did I disable cags right?
  67. Good tunning?
  68. LT1 tuning/diagnostics
  69. misfires
  70. need technical advice
  71. Learning how to Program
  72. PCM locked out by Ed Wright. Need options
  73. Lean at part throttle?
  74. A few questions on DFI
  75. Spark Retard without increased Knock Counts?
  76. OBD1/OBD2 Question
  77. 383" 224/236 36#injectors ... will this work?
  78. Tip in problem
  79. Tip in problem
  80. FreeScan Help
  81. Any info on Pcmforless dyno tuning would be greatly appreciated!
  82. How can I make the car go into closed loop faster?
  83. TunerCat puestion
  84. Racing CAGS
  85. 93' no spark adv & ping w/ load?
  86. Computer corrects too lean...
  87. Question about 1997 LT1 program
  88. Fuel , Air , Spark , Technology
  89. TunerCat EEB file
  90. Need Eprom
  91. 93 lt1 Accel DFI base Calmap file needed
  92. no fuel pressure
  93. ODBI Big Convertor shifting problems
  94. hot cam tuning lt1_edit
  95. good program for a long list of mods?
  96. ECU Pins
  97. Minimum computer requirements for LT1 edit.
  98. how to lean out the car..CC306..PIG RICH!!!
  99. electical masters.. please come in
  100. I still have a problem
  101. LT1-Edit
  102. obd2
  103. who does good tuning in illinois????
  104. Cam specs...Where do I change???
  105. spark curve
  106. to port or not to port (MAF)
  107. Tunercat installation problem
  108. Can Tunercat be run on a comp with 16MB RAM?
  109. Crower Cam tune please look
  110. EFI Live help site
  111. LT1 edit
  112. need a file for hotcam kit w/ ported heads
  113. Could to little timing cause Knock Retard?
  114. Need a lt1 edit file for a stock lt1 supercharged car.
  115. do we have an electronic device for measuring HP yet?
  116. Just got tunercat where do i start???
  117. 383 guys, how much timing
  118. can someone with LT1 edit or tunercat help
  119. Tech 1&2, Tunercat- How to make compatable
  120. airbag light????HELP???
  121. Need help with computer
  122. OBDII LT1 Edit-Deleting Crank Position Possible?
  123. PCM flash chip repair
  124. Need some timing maps from some of you...
  125. Stupid Question. Quick and straight the point.
  126. Anyone have a tune for xe 224/230
  127. Can you soften a hard shifting tranny with tables?
  128. What year cable (laptop to pcm) do i need?
  129. Easiest way to delete CAGS with OBDII
  130. Is VIN an issue with OBDII in this case??
  131. PC to PCM cable? Can you...
  132. Need to find shop to tune car!!!!!1
  133. OBDII vs. OBDI conversion questions
  134. tuning for a v6
  135. pcmforless.com programming & dyno tuning?
  136. Anyone have a 96/97 A4 .bin file (or .lt1)?
  137. Split BLM's @ idle and low RPM's. Any data monsters willing to take a look?
  138. cant get it right. anybody have some good programs or good advice? 1.6 and LT car
  139. Problem, dont know if it has to do with advance, PE, or what
  140. What does DFCO stand for?
  141. What are the best sites to get .bin files?
  142. Freescan question
  143. Need stock M6 OBDII tune...
  144. What from OBDII transfers over from OBDI
  145. Where is LT1-Edit's home page?
  146. cable help
  147. shift point help
  148. Advice for programming 383...
  149. In tunercat what is CAT protect program
  150. Open loop vs closed loop tunning
  151. laptop for lt1 edit
  152. Laptop requirements for Tunercat/LT1 Edit?
  153. 12.5 or 13.0 AFR?
  154. What would happen to my o2 if i left it out of the bung?
  155. Need help with PCM on Bench Dyno......
  156. AKM Calbe = Cable Needed for AutoTap?
  157. Need injector offsets..
  158. fast and opti
  159. PE VS RPM tables
  160. Ccp %
  161. P0404/p1404
  162. Various part-throttle tuning ?s
  163. O2's, LT's and cold weather. Q's
  164. Hypertech cable same as LT1 edit?
  165. Tuner CATS Help - Simle Question
  166. .bin files
  167. VE Master
  168. Tuning For xe cam and stage 1x heads
  169. Should I remove knock in PCM?
  170. ODB2 to ODB1 swap ? & LT1 edit Install ?
  171. Can I upload a program on to my PCM if....
  172. ECM Not Responding!!
  173. Help!! Please!!pcm Definition File!!!!
  174. Used 94/95 LT1 PCM's? Where to buy???
  175. can you upload a 95 LT1 tune to a 94 LT1 pcm?
  176. pcm lock up?
  177. Programming out CPS?
  178. Bin to LT1 edit?
  179. Converting OBDI programs to OBDII
  180. HELP!! need CC306 emissions file for TunerCat
  181. False Knock??
  182. What is OBDI LT1 edit locked to?
  183. A Few Computer ?'s
  184. code p0410
  185. Knock Recovery Rate??
  186. LT1/BIN file for 95 Z28 M6 with HypTech Power Prog.
  187. freescan
  188. Tranny slippage
  189. car going crazy please help
  190. Show me your odb1 connector!
  191. when stopping I get idle issues.
  192. Superfueler guys come in
  193. PCM Resetting SES Codes by itself?
  194. ANother Programming Question... Throttle Body
  195. Anyone running a FAST?
  196. Stock ign.map from LT1 wanted
  197. ecm and 7000 rpm ?
  198. Injector Programing????
  199. Opt-Spark can be cleaned!!!
  200. Anyone using an EMP-10 to reprogram thier Flash chips... Questions inside...
  201. Pros/Cons of all tuning/diagnositc programs
  202. Super Quick programming Question??
  203. What things cause "Limp Mode"??
  204. DTC 42 and arcing problems
  205. Do You Have My LT1/BIN File ?
  206. split BLMs
  207. Torque management
  208. Dirty MAF = Rich?
  209. any program out so i can change the VIN in the PCM?
  210. just logged a drive, have ?'s
  211. LT1 Edit gear change
  212. Custom programming a 93, is chip soldered
  213. Dyno Tune vs. Others
  214. Anyone have/know of any good stroker tunes?
  215. New to programming - when do I need it?
  216. pcm4less or get tuned on dyno
  217. Interface Cable
  218. How will my computer respond to long tubes?
  219. LT1 Edit
  220. WOT converter lockup and dyno shift file
  221. F-body 93 PCM vs 94-97 PCM
  222. computer tuning
  223. HELP with closed throttle spark advance
  224. Anyone mod their A4 tables for Autox?
  225. Looking for a nice laptop
  226. BLMs at 108. What is wrong and what is the best fix?
  227. LT1 edit tuning for larger injectors
  228. Does Anyone Have A Lt1 Edit File For A 12 Psi Vortech W/50 Lb Inj.
  229. Why Can't I Check Codes?
  230. Lt1 Edit List
  231. Lost timing on 7730
  232. LT1 edit prrgram for 230/236, or 236/242
  233. Tunning for best power?
  234. TunerCat Definition file
  235. Hypertech Book?/Manual? where can i get?
  236. tuning sites
  237. 93 LT1 What are my Tuning Options?
  238. PCM question please help??
  239. Shift rpm problem
  240. anyone here use fast tracks harness for accel DFI?
  241. Should I bother
  242. I have some questions about LT1_edit
  243. Anyone using http://www.obd-2.com software
  244. Limp Mode
  245. Need help with laptop please. Missing file Msvcp60.dll???
  246. interface cable questions?
  247. Anyone need some spare ECMs?
  248. Would minor head work Hot cam and 160 stat cause low BLM's
  249. BLMs steady 108 after tune...
  250. Changing Shift Points for a 95 Camaro
