PDA
View Full Version : Computer Diagnostics and Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
  1. where to buy tunnercat?
  2. Changing degree extension
  3. VSS used for engine operating parameters?
  4. Removing Cats?
  5. MAF Calibration Tables
  6. Cable Compatibility (AKM or Moates with Turbolink)
  7. disabling vats didn't work, how do i do it.
  8. Can't get PCMCIA card to work with Datamaster???
  9. Cheao tuning laptop on ebay
  10. hotcam .bin vs. zz4 .bin
  11. Anyone bored? Take a look at my PCM .bin and DM log.
  12. Hard to Start for Awhile, Now SES and DTC's
  13. Programming Retard for Nitrous/or msd?
  14. lt1 tune w/ cc306 & 1.6:1 rr
  15. Stock 94 Z28 Auto tunercat bin
  16. quad driver
  17. can i pass smog with cc305??
  18. Looking for a Comparable Tune
  19. MAF-translator be used to cure cam-surge?
  20. Hypertech Custome Chip Question
  21. 93 speed sensor
  22. Pulling timing for Nitrous, what table?
  23. BLM Locker. Where to download?
  24. Normal, Hot and Cold mode in TC
  25. Cheapest, easiest, best way to reprogram for gears
  26. need a Ed right file
  27. Dyno day with PCMForLess - big increase
  28. A little help please
  29. software to tune
  30. Air pump 2 electric h2o pump ckt
  31. AirBag/ABS INOP HELP (long)
  32. tuning for idle with a/c on?
  33. cant get connection on a 94 with datamaster
  34. Lean code on banks 1 & 2.
  35. Computer Tuning Issues
  36. fuel tunning
  37. Possible to mess up PCM by aborting a read?
  38. surge, data logs, tune file..need assistance
  39. o2 sims
  40. anyone ever hear of this dude?
  41. Please check out blown Z .lt1 file
  42. datamaster
  43. No Speedo, Replaced the VSS, What should I check???
  44. Cell 18 for WOT........
  45. Speedo's out, replaced the VSS, PCM knows speed, Speedo doesn't...
  46. Weird WOT thing occuring.
  47. logging/scanning a 93?
  48. Wiring in a new Tachometer
  49. lt4 knock modulator???
  50. Fooling the PCM to get the EGR monitor ready
  51. just how different is tunercat than lt1 edit? need to know best bang quick!
  52. GM ESI available online
  53. TTS Datamaster Trans Question...
  54. check engine light???
  55. Sanman?
  56. AutoTap - no parameters!
  57. installed F.A.S.T. no start!!
  58. Tuning Question
  59. using a 94 cable to log a 95
  60. skipshift light turn into shiftpoint light
  61. Question about Accel DFI Gen VI...
  62. Burst Knock
  63. 93 conversion. No fuel. HELP!!!!!!!!!
  64. Driver By Wire, new LS2 Electronic TB
  65. bad PCM?
  66. Nitrous Tune vs Regular tune??
  67. need stock bin file please!!
  68. How to turn off SES light?
  69. pedal position decreases power
  70. Free Sony, IBM or Gateway Desktop Computer !
  71. Free Gateway, IBM or Toshiba Laptop !
  72. Need USB adapter for AKM cable.
  73. info
  74. LT4 Tunning.
  75. URGENT: tunercat owners read
  76. Need comparison file
  77. need a scanner for 94
  78. how quick can values change?
  79. PCM SES light.
  80. recommendation?
  81. PCMforless tuning...
  82. Tuning for 87 octane
  83. Started Tuning :)
  84. base stock tune for FAST?
  85. EE and EE_B def differences....i need some help please
  86. Tranny changes get good results.
  87. LT4 binary file....can i borrow one to look at?
  88. freescan log
  89. Tuning, Nitrous, and Race Gas...
  90. datamaster
  91. Airbag light is on... why? and how do i fix it?
  92. The case of the "Knocks"
  93. problem with idle surging in an 89 iroc datamaster-32
  94. looking for tuner in 4 courners region.. Co/Ut/Nm/Maybe AZ
  95. is there anybody with the answer?
  96. electrical problem
  97. LT1 Timing options
  98. Tuning to eleminate predetination
  99. Cold starup require more fuel?
  100. Tuning for driveability using Datamaster and TC
  101. diagnostic tool info
  102. interpreting ecm data
  103. file needed 95 z28 t56 with 3.73s
  104. Programming out ABS
  105. easy tunercat questions
  106. Programming for cc305 w/ lt1 edit
  107. Need help with Service vehcile light!!!
  108. Lean spike before WOT
  109. Diagnose problem. 1/2-3/4 throttle car "misses"
  110. Injector Fault?
  111. Target AFR on the Dyno
  112. Splicing into PCM harness
  113. Larger T/B Where to start tuning.
  114. Question about lowering injector flow rate
  115. Wires required for ALDL connection
  116. Help please?
  117. Problem downloading trial version of Datamaster
  118. LT1 A4 to M6 PCM Ques
  119. people with good tunes
  120. AKM cable guys/gals....
  121. Questions about rear O2s
  122. Programmers/Tuners--- inside please
  123. OBDII question
  124. 95 3.4 jet chip question
  125. free scan
  126. code-bank 1 sensor 2
  127. scanmaster ?
  128. O2 Sim. installed but S.E.S. light still comes on???
  129. Open Loop Question/ Bog off idle (Wideband)
  130. 2001 V6 Camaro tuning...
  131. Loading Gen 7 on a Gen 6 Accel system?
  132. MAF max freq fail
  133. 95 lt1 m6 file needed
  134. '96 M6 .LT1 file needed
  135. Program or not to program
  136. hypertech or custom chip??
  137. props to madz tuning
  138. Laptop for tuning/Good deal or not?
  139. OBDII vs OBDI in a OBDII car good or bad
  140. Freescan for Electrical Faults
  141. LT1 with No Spark or Injector Pulse
  142. hot cam to cc305 do I get flashed
  143. Idle problems
  144. Please help w/a code
  145. quick hypertech question
  146. PCMforless vs. MADZ28?
  147. hypertech power scan program
  148. Need help getting Datamaster to work on my laptop with PCMCIA card!
  149. does anyone have a stock bin from a 93 Z28
  150. scan tool(obd2)
  151. Fuel pump signal out of PCM
  152. SES code
  153. Datalogging Problem
  154. Checked out my cable ... is this right ?
  155. AEM wideband...?
  156. Torque converter solinoid signal
  157. Tuning a vette.
  158. AF question?
  159. LT1 Tuning Q.
  160. Very cheap PCM cable
  161. Need help with code po1629
  162. Palm Pilot Data Logger?
  163. A way to disable KR at WOT?
  164. Are there ANY companies that actually sell cables ?
  165. How to save stock programing, updating to MADZ28 tune.
  166. what size injectors?
  167. PCM programming - suggested settings?
  168. Throwing codes - MALF 26,27,29
  169. BLMs at 160 all the time?
  170. Strange Idle Surge
  171. First day of dyno tuning yesterday; yikes...long
  172. P0400 EGR & P1361 Codes on OBD2 LT1
  173. fast ecu
  174. Help with tuning
  175. Freescan Help!!
  176. Help with Freescan!!!
  177. OBDI Conversion and High Idle
  178. PCM reset before every start? why?
  179. imposible diagnostic *MAF glitch*
  180. Need a starting point for revised BLM boundaries
  181. Welding on car... PCM precautions?
  182. my long term fuel trim jumps (normal)?
  183. seral to usb
  184. Tunning a Nearly Stock GMC Denali
  185. dfi dyno problems
  186. Need DTC Def. Help
  187. quick C.A.T.S tuner help
  188. 02 sensor can cause knock retard....
  189. GM Tech 2 Question...
  190. GM TECH 2..question
  191. Idle adjustment??
  192. extending oxygen sensor wires
  193. What can i tell from Datamaster.
  194. Ion, tell me something
  195. Tuning ? For beginner
  196. Convert LT1 to wideband o2?
  197. No knock count but still pulling timing???
  198. Datamaster Rpms Variances(T.C. Adjustments)
  199. Freescan help!!!
  200. Very interesting OBDII emissions test results
  201. Help me decide/Laptop to 95 z28. want to edit pcm/view/erase codes/and view obd ii 2
  202. ABS tied to the PCM?
  203. My Doors Wont Lock Or Unlock!!! LS1
  204. Datamaster or other scanner..
  205. Tuning to make stock LT1 pass sniffer w/ no cat
  206. Malf 24 Datamaster Code
  207. How dependable is VE master?
  208. Any Hp Tuner's in Texas?
  209. Will this scanner work on a '94?
  210. need help deciding on tuning
  211. tuner car ?
  212. Tunercat $EE file
  213. Running a TH400 in a 96 ODB II Z28.
  214. Computer Swap
  215. which data scanner to use?
  216. Tcs Switch
  217. malf 97 and haywire speedo
  218. MadZ28 Rocks
  219. First Time DataMaster user...Need Help!!!
  220. diagnostic troubleshoot codes
  221. Tunercat Help
  222. 11.45 volts ok for MAF to work properly?
  223. need a 94 z28 bin file
  224. Best tuner in Colorado/New Mexico/Utah/Arizona
  225. OBD1 conversion
  226. Speedo calibration
  227. Code 57 pulled from BCM
  228. Usb Comport Adaptor
  229. Megasquirt opinions
  230. computer mounts
  231. Best Tuning software/ cable for 94 LT1
  232. Aem Wb
  233. n00b question on a 95 3.4
  234. Need guidance
  235. Diagnostics connector pinouts
  236. Engine starts, then stalls
  237. Short term max
  238. How to lean out my tables in my PCM???
  239. Tuning OBD2 cars with emission testing.
  240. tunercat EE vs. EEB
  241. Question regarding Injector..
  242. Something new in Summit
  243. Best Wideband Sensor?
  244. ordering tunercat definition file
  245. How important is....
  246. What are the throtle follower tables?
  247. big cam and vacuum ?
  248. Difference between high cool and low cool
  249. What timing adv is everyone running?
  250. 02 sensors question
