Car running rich. what do I change; lt1 edit
I have LT1 edit. My car is running rich. What table should I change? I am burning gas and I catch it sometimes smoking when I get on the gas. any help would be great.
Do a search under this forum using the word "rich" and "MAF". You should come up with this discussion a few time.
I was involved in a few of those discussions. Basically, (and check other posts) you want to change you MAF tables. Now there is a lot to being rich so just don't go changing because we say so. Make sure that nothing else is causing your situation (leaking headers etc. etc. -check posts).
GL and tell us if you cannot find what u are looking for.
Ben
Ben
My car was also running rich, so with Tunercat, I increased the size of my injectors, effectivly tricking the computer into spraying LESS fuel... Mixed my problem perfectly!!
While there must be a reason for the car running rich, I have yet to find it
And this is just a bandit for the problem and with any luck it isn't causing any harm, but I know of multiple people on here that have fixed this same issue this way...
Of course, do this at your own risk
Jeff
And this is just a bandit for the problem and with any luck it isn't causing any harm, but I know of multiple people on here that have fixed this same issue this way...Of course, do this at your own risk
Jeff
ro2207
Dec 4, 2014 06:18 PM
Jul 4, 2005 05:00 PM
