afr at idle?
Old Nov 26, 2002 | 11:04 PM
Deadcarny's Avatar
afr at idle?
this may sound like a stupid question, but i need to know. what table to i adjust to change my AFR at idle? i know how to do WOT tuning, but what should i do for regular tuning?
Old Nov 27, 2002 | 02:54 PM
Grover's Avatar
That depends on if you are running open loop only, because in closed loop the PCM will constantly adjust for 14.7:1 AFR. Lots of people run PE idle by setting the throttle percentage for PE to 0% at 800 & 1200 RPM then you can adjust by the PE vs. RPM table.
Old Nov 27, 2002 | 03:13 PM
95Blackhawk's Avatar
Hey Grover
Do people do this to save on gas?
What is the reason for doing it. sounds interesting, but why do it?
Ben
Old Nov 27, 2002 | 05:30 PM
Dan K's Avatar
I believe it is done mostly to counter the effects of a large cam and reversion in the intake that sends your blm's wacky at idle.
As far as a/f ratio at idle...stuff like that should be taken care of by the mass air flow sensor and O2. What problems are you having that you think this is affecting?
Old Nov 27, 2002 | 07:18 PM
Grover's Avatar
Hey Grover
Ben
Dan was pretty much right on most of the reasons. But I did it because my car was so rich at idle it would hurt your eyes. I had to crank up my fuel pressure so high that I wasn't going lean at WOT and in turn it made the car rich at idle.
Old Nov 28, 2002 | 01:24 AM
Dan K's Avatar
Chad-
Isn't that an indication of inadequate programming or undersized injectors?
Seems to me that bumping up fuel pressure in order to tune WOT is a band-aid fix....that's all.
Anyways, how did the PE idle work for you?
I tried it on a buddies 93 and couldn't get it to work. Apparrently the 93 computers are different as far as getting the car to idle in PE mode....I still haven't figured it out.
Old Nov 29, 2002 | 08:32 PM
Grover's Avatar
Originally posted by Dan K
Chad-
Dan you are correct. At the time I couldn't afford larger injectors so I just turned up my fuel pressure so I wasn't >100% duty cycle on the factory injectors. I have some 39# injectors that are going in over the winter and will be doing lots of tuning next spring. I will be going back to closed loop idle to see if I have the BLM split that is caused by large cams at idle.
bunker
Aug 21, 2015 10:21 AM
Bails098
Aug 17, 2015 05:15 PM
realistyc
Jul 28, 2015 07:32 PM
C4m4roJoe
Jul 19, 2015 10:59 PM
Catmaigne
Jul 14, 2015 05:17 PM
