Code 43 Question
Old Oct 13, 2003 | 08:27 PM
aklim's Avatar
Code 43 Question
I am out of the house and don't have access to my scanner. Can anyone tell me what to look out for? I have borrowed a friends new Knock Sensor but driving it around it still has the Code 43. Thanx
Old Oct 13, 2003 | 11:21 PM
90rocz's Avatar
Do you have 5volts at the sensor with key-on, engine off?
if yes, ohm out the sensor, it should be between 3300-4500ohms.
If good ohms, check the connector for good contact. Be sure the chip is fully seated, if ok replace chip.
if ohms out of range, faulty sensor, replace it.
if NO, less than 5volts, check for an open, or grounded wire feed or ECM bad.
if NO, more then 5volts, see if the wire is too close to plug wires, or shorted to voltage, or bad ECM.
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
cmdeshon
Dec 27, 2014 10:06 AM
Jul 4, 2005 05:00 PM
johnsocal
Aug 29, 2002 10:01 AM
91Bird305
Aug 5, 2002 01:39 PM
