Fuel Pump Question
Old Oct 19, 2003 | 05:31 PM
Kuruption562's Avatar
Fuel Pump Question
Aiight i just bought my fuel pump, i asked the guy what else is needed and he gave me this lil thing that looks somethin like a lil filter it was like $6, my question is, is there anything else i need when i get it installed? My uncle is gonna install it, hes a mechanic. Thanks.
Old Oct 19, 2003 | 05:46 PM
kandied91z's Avatar
why don't you just ask your uncle? my pumps came with everything i needed although they were gm and walbro. what did you get?
Old Oct 19, 2003 | 05:58 PM
the brand is Master.
Old Oct 19, 2003 | 06:33 PM
kandied91z's Avatar
i never heard of it....was it cheap?
i know the gm and walbro pumps which typically are very good go anywhere from 60-100. pay a little now and a lot less later. i would assume it comes with everything you need if it's made for your car as there really isn't much to them.
Old Oct 19, 2003 | 11:07 PM
iT WAS 63.99 PLUS 5.99 FOR THE FUEL STRAINER, SOMETHIN LIKE THAT. IM PRETTY SURE IT HAS EVERYTHING I NEED I WAS JUST MAKIN SURE THO, WELL MY UNCLE DIDNT COME BY TODAY, HE SAID HE'LL BE HERE TOMARROW THO
Old Oct 19, 2003 | 11:32 PM
MasterEvilAce's Avatar
the 7$ object was the Fuel filter
you'll see it when you drop the tank (i think you have to remove it before you drop the tank)
not real sure... but yeah
Old Oct 19, 2003 | 11:43 PM
90rocz's Avatar
One tip: I always throw the so called "muffler"(between pump and top of assembly) away and install a good piece of fuel hose and secure it with screw-clamps. Nothing worse than replacing a pump, only to have a pressure leak in the tank that drops the fuel pressure or volume. Keep the lower clamp from touching the pump power terminals tho...
Sounds like you got a standard replacement pump. It would be a good time to look into a high performance one, only $30 or so more and you save youself the labor of having it done later as the modds pile up....
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
RiverMutant96
Jan 30, 2015 09:21 AM
Jessie4tin
Jan 7, 2015 08:53 AM
ANDYZ28
Dec 29, 2014 09:13 PM
