Dying up top
Old Oct 14, 2003 | 07:57 PM
buzz12586's Avatar
Dying up top
Once my car hits about 3 grand I can feel it stop pulling. It used to stop pulling around 4 grand. I think it may be my fuel filter being clogged cuz I am gonna change it tommorow. Can anyone think of any other possiblities???
Old Oct 14, 2003 | 09:04 PM
90rocz's Avatar
Two things, worn or damaged valvesprings or weak fuel system/pump.
Old Oct 14, 2003 | 10:44 PM
aklim's Avatar
Compression test it. If that checks out then go for the fuel pressure and spark.
Old Oct 15, 2003 | 11:37 AM
buzz12586's Avatar
I do think my valve seals are going because it smokes oil on startup. Would this also mean my valve springs were going?
Old Oct 16, 2003 | 08:57 AM
aklim's Avatar
Not necessarily true. But in any case, how would you change seals without removing the valve springs? Would be a neat trick to watch. So, with it out, why not check them at the same time?
Old Oct 17, 2003 | 11:45 AM
buzz12586's Avatar
How would you be able to tell if the valve springs are bad?? I am not an auto mechanic or anything.
Old Oct 17, 2003 | 01:58 PM
Rice Killer87's Avatar
ull need a valve spring tester. u sit the spring on a flat piece on the tester,pull a lever down and another flat surface presses down on the spring and there is a gauge on it to tell u how much resistance it has (i think its resistance).
Victor Lamb
Aug 26, 2017 02:52 PM
andrewcapps82
May 19, 2015 10:11 PM
reww86
Apr 27, 2015 05:17 PM
BigWil
Mar 29, 2015 12:24 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
