275's on my iroc-z?
Old Nov 4, 2003 | 12:40 AM
dj haf's Avatar
275's on my iroc-z?
could i fit 275's on my stock rims? would they fit fine, or would i have to buy something for them to fit? thanks guys
Old Nov 4, 2003 | 11:01 AM
85_LG4
Guest
Posts: n/a
Well.. what size tires did your car come w/? An IROC has 245's I believe..
275 "SHOULD" be ok, but I am unsure. I have stock 15's, and they take 215's originally.. I am gonna put 245's on them though, I am positive that will work. If 275's fit you car, which I believe they will, they will kinda bulge out of the rim, and the patch of tire touching the ground, and give it a kool look.
Old Nov 4, 2003 | 12:05 PM
shwine617's Avatar
I have 15 inch rims on my car with 265 tires on the back and they fit fine, I actually just got them and only drove down the street until i got a hole in my oil pan, They fit niceley though, but i never hit any big bumps yet so i don't know if they will rub when i hit a bump. My freind has 295, but he has a nice torn up spot going around his tire from rubbing.
Old Nov 4, 2003 | 12:50 PM
kevin 2.8's Avatar
jack the back
j/k
Old Nov 4, 2003 | 12:55 PM
85_LG4
Guest
Posts: n/a
265's out back???? No ****.. maybe I will be gettin 265's intead of 245's.. lol.
I would think those 275's would fit "PERFECT" on your 16's!!
Old Nov 4, 2003 | 01:04 PM
dj haf's Avatar
lets hope so...i need traction lol
Old Nov 4, 2003 | 02:28 PM
Black6SpdTA's Avatar
Anyone know what will fit up front with NO rubbing and 16" wheels? I've already got 245's, can I go bigger up front?
-Rippin
Old Nov 4, 2003 | 03:25 PM
shwine617's Avatar
I like 15 inch rims better than 16, but my car had 245's in the front
on a 16 inch rim and it fit fine.
the front rims i just got are 15 x 4 1/2 with 195's.
Its a little skinny but i like the look. I have a pair of 205x15 that I may try to squeeze on them.
I really want a set of traction action bars and adjustable coil overs so i could fit 295's in the rear with no problems
and maybe one day a 12bolt posi so i can get traction from both tires instead on just one.
Old Nov 4, 2003 | 07:35 PM
AutoRoc's Avatar
275/??/?? 16's? What tire exactly? What aspect ratio? 245's on a stock IROC 16X8" rim is as big as I'd go. It looks normal, handles good(is safe), and price wise it's cheapest probably.
I got a buddy who put 275/50/15's on his 15X7" rims...Looks terrible, handles like ***, rubs.. LOL!
Old Nov 4, 2003 | 08:08 PM
doug791's Avatar
i run something like 255/50/16's???i forget the sidewall depth but theyre 255's
Old Nov 4, 2003 | 11:23 PM
dj haf's Avatar
275/40/R17 16'' stock iroc-z rims
Old Nov 5, 2003 | 10:57 AM
85_LG4
Guest
Posts: n/a
I would honestly leave your stock size fronts on. I have 215's up front stock, and would leave it that way due to better handling than a larger tire, and keeping it safe.
Old Nov 5, 2003 | 11:16 AM
dj haf's Avatar
i want to keep the 245's up front and 275's in the rear... just wanted to know for sure if they'd fit. anyone running 275's or something close to that on the stock 16'' iroc-z rims?
Old Nov 5, 2003 | 11:19 AM
doug791's Avatar
most tires have a specific sizing so figure out what you want to buy and it should tell you what the most ideal size for a 16x8 rim would be. Theres generally no need on street tires for something that wide unless youre going with a set of et streets or something.
Old Nov 5, 2003 | 05:01 PM
AutoRoc's Avatar
Those tires don't fit those rims. That's a 17" tire and a 16" rim. Those tires fit of course but they need to be on a 17X8.5-17X9.5" rim. Goodluck! Going from 16's to 17's is an awesome step in handling. That size tire is probably the cheapest in a 17" also since it's popular on 4th gens also.
