Front Disc Brakes
Old Oct 29, 2003 | 04:55 PM
grahmcam89's Avatar
Front Disc Brakes
I installed new disc brakes sunday and now when I push on the brake pedal I hear a hissing sound and it is hard to press the pedal and stop. Any suggestions on what is wrong? I followed the Haynes manual to change my brakes. Please help
Old Oct 29, 2003 | 05:07 PM
Kuruption562's Avatar
Were you ruff on them the first days they were on?
Old Oct 29, 2003 | 05:09 PM
grahmcam89's Avatar
Not any more than I was the last time I change them about 1½ years ago.
Old Oct 29, 2003 | 05:15 PM
dave89gta's Avatar
Bleed the lines and check the fluid.
Old Oct 29, 2003 | 05:25 PM
grahmcam89's Avatar
Do I need to bleed both front and back?
Old Oct 29, 2003 | 05:26 PM
dave89gta's Avatar
I would do both. Brakes are the most important system on your car.
Old Oct 29, 2003 | 05:29 PM
grahmcam89's Avatar
Thanks. I will do that and let you know what happens.
Old Oct 29, 2003 | 06:11 PM
TheGreatJ's Avatar
The hissing points toward a vacuum or high-pressure-fluid leak, and the hard pedal could easily be caused by lack of vacuum to the brake booster. Check the vac line for the booster and also check to see if the booster itself will hold vacuum. The check valve may also be a culprit, but that generally doesn't cause a hard pedal.
R@mpage
Apr 20, 2015 10:02 AM
CGM2010CAMARO
Apr 7, 2015 07:44 PM
Jlo
Apr 3, 2015 10:32 AM
hotrodyou1
Dec 20, 2014 10:05 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
