fuel pump q's
Old Nov 3, 2003 | 05:00 AM
lil305gta's Avatar
fuel pump q's
Has anyone replaced their fuel pump with an aftermarket one such as Holley? What is the quality of theis part or should I replace it with the OE parts? Thanks!
Old Nov 3, 2003 | 08:58 AM
aklim's Avatar
I used the Walbro one and it went well. I believe the Granatelli one is supplied by Walbro. BTW, it was the 225 one.
Old Nov 3, 2003 | 09:06 AM
rudy's Avatar
I used a stock Delco replacement. No problems, and it is a fairly modified motor.
Old Nov 3, 2003 | 11:00 AM
Zepher's Avatar
I replaced my mech pump with an inline holley pump when I converted to TPI and had no problems with it.
One of my friends is using my holley pump on his modded 355 in his 86 Z28 and it runs great in his car. My pump is 230/lph.
Old Nov 3, 2003 | 11:44 AM
aklim's Avatar
The delco one is fine but AFAIK, it is more money unless you have connections at a dealership and the rated flow is not as high.
Old Nov 3, 2003 | 06:08 PM
dj haf's Avatar
hey, wut are the specs on the stock fuel pump? im curious to know
Old Nov 3, 2003 | 08:14 PM
DarkRider's Avatar
I would say it depends on if you're pulling the tank or cutting out the hatchback.
If pulling the tank get a good one(I think delco would be fine) because its a bitch to pull the tank
If cutting out the hatch( what I did) take your chances with a cheap one from auto zone
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Black Sunshine/ 00SS
Sep 15, 2002 10:08 PM
