Need your opinion
Old Oct 20, 2003 | 03:34 PM
350ws6's Avatar
Need your opinion
Is it possible for this engine to get to 300hp?
IT is in a 1980 vette, stock L-48 rated at 190hp. The engine has 8.2:1 compression and a cam with a lift of .390/.410 lift.
My friend thinks by adding just headers and exhaust,an intake, and timing it can make 300hp. With the stock cam and heads. Is this possible, a 110 hp gain from those mods, or another overzealous vette owner?
Old Oct 20, 2003 | 03:56 PM
Marc 85Z28's Avatar
Intake and exhaust would put that motor around 230-240HP, tops. No way he will make 300 without going into the motor or using some sort of forced induction.
Old Oct 20, 2003 | 04:40 PM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
A motor that old could probaly use a refreshing rebuild anyway.
Pull out the motor, get the heads machined a little and put in flat top pistons to bump your compression up to about 9.5:1. Then add a more modest cam with say .470 or so lift.
Then do your exhaust. With probbaly about a grand spent you can easily be making more than 300 hp. It would be really hard to get over 300 hp with such a wimpy cam and compression.
But with a better cam, and a little head porting, you can be thre easily.
Ks0209
Oct 1, 2015 07:32 AM
drt
Sep 27, 2015 04:39 PM
SEOJustin
Sep 24, 2015 04:39 PM
jackpawt883
Jul 31, 2015 08:15 AM
birdblack
Jul 8, 2015 07:23 AM
