I can smell gas...
Old Oct 16, 2003 | 11:17 PM
mako350Z28's Avatar
I can smell gas...
in the exhaust even after it has idled down. Anyone have any suggestions as to what it may be?
Old Oct 17, 2003 | 12:03 AM
MasterEvilAce's Avatar
running rich, most likely
any error codes?
Old Oct 17, 2003 | 12:53 AM
camaro6's Avatar
Your probably running rich
Old Oct 17, 2003 | 02:15 AM
Kuruption562's Avatar
whats that mean
Old Oct 17, 2003 | 03:01 AM
redimpss5's Avatar
ooops, to many beans!! hehehe could help it!
Old Oct 17, 2003 | 07:31 AM
Pro
Guest
Posts: n/a
This could mean a ton of things. Iv discovered so far a couple of things with my car that has lead to running rich.
First, I had an EGR problem - some of the lines were full of carbon and gas fumes were leaking out of the system.
Second, after doing a tuneup, I found one of the spark plugs (If I remember it was from cyl 7) had absolutely no gap at all.
Old Oct 17, 2003 | 10:13 AM
mako350Z28's Avatar
No error codes, car runs smooth and does not seem to skip or miss.
Old Oct 17, 2003 | 10:30 AM
kevin 2.8's Avatar
o2 sensor or timing off
Old Oct 17, 2003 | 02:37 PM
yeah.. O2 sensor should be changed every ~30,000 miles i believe/...
Old Oct 18, 2003 | 06:16 PM
where is my 02 sensor located? where can it be bought?
Old Oct 18, 2003 | 07:15 PM
DrDUKE's Avatar
should be on the driver side header. right before the collectors. They cost about $20 at any auto store. They are kinda a pain - i just did it today. Bit wrench something like 21mm?? anyway its big and there is not much room to work. I guess they make a special socket for it, ask if they rent it when you buy it at the auto parts place.
Old Oct 19, 2003 | 12:37 AM
they do make a special socket
the size is 7/8th
i've attempted 3 or 4 times already, but havn't got it off, yet. I'm probably going to end up taking a bunch of crap off so i can get to it easier
as for location: on the driver's side, it's near the last sparkplug, i believe. you can't miss it, if you're looking near the sparkplugs
Old Oct 19, 2003 | 02:00 AM
dj haf's Avatar
i used to get a gas smell from my car when i was at idle ... my damn cats were clogged to death. took them out, smell went away. there was this one time though i smelled gas again but it was a different smell and it was because i needed to change my O2 sensor.... change your fuel filter while your at it, if you need to change your o2 sensor, you probably need a new filter too.
Old Oct 19, 2003 | 02:05 AM
alright thanks ill have my mechanic look at it tomarrow. So i just walk in the auto store and ask for an o2 or 02 sensor for my iroc? do all cars have these sensors?
Old Oct 19, 2003 | 02:13 AM
90rocz's Avatar
Yeah, pretty much, most computer controlled ones anyways. It gives exhaust sampling data to the computer so it can trim the fuel mixture.
